Two Objects Connected by a Pulley: Solving for m1
  • Thread starter Thread starter JWSiow
    Pulley
The problem involves two masses, m1 and m2, connected by a string over a pulley, with a specific focus on the conditions under which m1 comes to rest. The context includes the effects of friction, with a particular emphasis on the interpretation of the friction coefficient being zero.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants explore the implications of the friction coefficient being zero and question whether this means to ignore friction entirely. There is also discussion about the clarity of the question regarding the position of m1 when the system comes to rest and how to determine this position based on the angle θ.
The discussion is ongoing, with participants raising questions about the wording of the problem and the assumptions regarding friction. Some have suggested potential approaches to interpret the problem, but there is no consensus on the exact meaning of the conditions provided.
Participants note the ambiguity in the problem statement regarding friction and the unclear phrasing of the question about the position of m1. There is also mention of the forces acting on m1, including gravity, normal force, and string tension, which adds to the complexity of the interpretation.
JWSiow
Two objects with masses m1 of 10kg and m2 of 2kg are connected with a string over an elevated pulley as shown and start to slide in the presence of friction.
http://www.freeimagehosting.net/uploads/06f5aea24d.jpg
If h=10cm and [tex]\mu[/tex]=0, where is m1 when the system comes to rest
I have absolutely no idea with this one...
Do you mean in the presence of friction μ = 0?
This problem requires some interpretation. What does μ = 0 mean? Can it mean no friction? Yet the problem says "in the presence of friction." It might mean "don't worry about friction as a force acting on the mass when the mass comes to rest", but I am not sure. Have you posted the exact wording of the problem as given to you?
Yep, that's one of the things that confused me. I assumed it meant ignore friction..
The question "where is m1 when the system comes to rest" is also a bit unclear. Suppose you could find angle θ. How would that help you determine where the mass is from, say, the edge of the table? The best you can do is to assume that the pulley has zero radius and find the distance of the mass to the center of the pulley.
My guess for approaching this (not so well-designed) problem is to say that the equilibrium position is where the normal force exerted by the table on m1 becomes zero. You can find θ from this condition.
It is stange, but we have no choice - we have to respect facts :smile:. There are three forces action on the m1: gravity, table reaction and string tension.
IF there is no friction there is unbalanced horizontal component of string tension. It is non-zero force until theta angle lower than 90 deg. And I can't see anything to balance this force.
This mean that system moves until point of force application locate preciselly under pulley?
Like blue one on the picture below
http://www.freeimagehosting.net/uploads/c78bf6258f.jpg
regards
Bartek
ps
But it is confusion me too.
Thanks anyway :) Any answer's better than none! Hopefully they don't put anything weird like that in my exam!
11K
  • · Replies 29 ·
