Lightbulb Brightness Homework: Series & Parallel Circuits
The problem involves two light bulbs with different resistances connected first in series and then in parallel with a battery. The original poster seeks to understand which bulb glows more brightly in each configuration.
  • Participants discuss the relationship between current, resistance, and brightness, noting that the original poster is uncertain about how these factors interact in series and parallel circuits. There is mention of using power equations to determine brightness.
Some participants have provided insights into the power consumed by the bulbs and how it relates to brightness in both configurations. The discussion is ongoing, with various interpretations of the principles involved being explored.
The original poster expresses confusion about the concepts and assumptions related to current flow and resistance, particularly in the context of the junction rule and its implications for brightness.
JWSiow
Two light bulbs of resistance R1=10 ohms and R2 = 15ohms are connected in series with a 25V battery. Which bulb glows more brightly?
Now the bulbs are connected in parallel with the battery. Which bulb now glows more brightly?
V=IR
...This seems like an easy question, but I just don't understand it! I know if they were the same resistance the brightness of each bulb would be the same, but don't really know why. I thought the amount of current passing through each bulb determined brightness, but then I read that from the Junction rule, the current through each component is the same!
Hey, the brightness depends on the power consumed by the bulb. When bulbs are in series,yes, as you said current flow is same. You calculate power consumed by each bulb now using relation
[tex]P= I^2 R[/tex]
from which you can find which bulb is more brighter.
When they are in parallel, surely, bulb with higher current through it (or which has lower resistance) will be brighter, since voltage here is same on two bulbs.
In series combination the same current flows through both the resistances. Brightness depends on the heating effect. And it is given by either I^2*R, or V^2/R or V*I. So in series combination larger resistance is brighter.
In parallel combination...?
Ok, thanks heaps!
