Thread Closed
Inrease in water pressure as a function of temperature under constant volume
Share Thread
Jun29-10, 06:58 AM   #1
Hi all. I have a large pipe network that can hold say 1000 cubic meters of water. The pipe network is closed and pressurized to say 10 barg at 25 deg C. If the temperature of the water increases to 55 deg C, how much will the pressure in the pipe network increase?
I would appreciate if you could point out the method of solving the problem including tables and formulas.
Thanks.
PhysOrg.com physics news on PhysOrg.com
>> Is there an invisible tug-of-war behind bad hearts and power outages?
>> Penetrating the quantum nature of magnetism
>> Rethinking the universe: Groundbreaking theory proposed in 1997 suggests a 'multiverse'
Jun29-10, 07:45 AM   #2
This ia a job for steam tables and the first law of thermo and possibly a H-S chart.
Jun29-10, 08:28 AM   #3
The water is between 25 to 55 degC so I don't think the steam tables or the thermo laws will do any good. This is a pressure vs temp vs volume problem. if it was a gas then a simple ideal gas law would work.
Jun29-10, 09:01 AM   #4
Quote by ageorgakis View Post
Steam tables, in an odd use of the nomenclature, include compressed liquid water. No idea why they are still called steam tables but they are.
You came and asked the question as to how to solve is. I've told you. It's water, therefore you use the steam tables, there is no debate about that. You find the heat transferred to the water (using the mass and specific heat capacity). As no work is being done (from the first law) we know that all internal energy comes from transferred heat. You can then look up from a steam table the pressure.
I've not used steam tables or done anything with thermodynamics of fluids in quite a while (since uni in fact), I can't remember exactly what you have to do i'll have to read up for that.
Jun29-10, 12:06 PM   #5
Quote by xxChrisxx View Post
It's been such a long time since uni I can barely remember any of this. I wish I had my old books. I'm doing some research on the net but it isn't easy.
Thread Closed
Similar discussions for: Inrease in water pressure as a function of temperature under constant volume
Thread Forum Replies
with what materials a strenght can a constant volume be kept under water pressure? General Physics 2
Water pressure, volume, temperature Classical Physics 1
[Thermo] Finding pressure given temperature, quality, mass, and constant volume Classical Physics 0
Constant volume versus constant pressure batch reactor Engineering, Comp Sci, & Technology Homework 0
Temperature change of water at triple point in a constant-volume gas thermometer Advanced Physics Homework 0
