Two bodies attracting via gravitation
  • Thread starter Thread starter Rats_N_Cats
    bodies Gravitation
The problem involves two bodies, m1 and m2, that are initially at rest and begin to accelerate towards each other due to gravitational attraction. The task is to express their relative velocity of approach as a function of the distance between them.
  • Participants discuss the relationship between gravitational potential energy and kinetic energy, as well as the conservation of momentum. There is an exploration of how to express the velocities of the two bodies in terms of their masses and the distance between them.
Some participants are providing guidance on substituting variables to simplify the equations. There is an ongoing examination of the correct expression for relative velocity, with different interpretations of how to calculate it based on the direction of motion.
Participants are considering the implications of the bodies' directions of motion and how that affects the calculation of relative velocity. There is a mention of the need to clarify definitions and assumptions regarding speed versus velocity in the context of the problem.
Rats_N_Cats
Say, there are two bodies, mass m1 and m2, initially at rest at infinite separation. They start accelerating towards each other because of gravity. Express the relative velocity of approach as a function of the distance between the two bodies.
Laws of Motion, Law of Universal Gravitation, Conservation of Momentum and Energy.
I thought the loss of gravitational potential energy should equal the gain in kinetic energy of the two bodies, so [itex]\frac{1}{2}(m_1 v_1^2 + m_2 v_2^2) = \frac{Gm_1 m_2}{r}[/itex]. Also, because of conservation of momentum, m1v1 = m2v2, because the two objects have zero initial momentum. But I can't figure out the velocities from these two; and I think that's what i need.
You're on the right track. Maybe you just need one more nudge. The second formula implies v2 = m1 v1 / m2. Substitute that into the energy equation and solve for v1...
Doing as suggested, I end up with the values for v1 and v2. Then the velocity of approach should be v1 + v2. I get for that [itex]v_1 + v_2 = \sqrt{\frac{2G(m_1 + m_2)}{r}}[/itex]. Is that correct?
When I calculate the problems for collision,
e=(speed of separation)/(speed of approach)
If two bodies are moving opposite directions, relative velocity is v1+v2.
If two bodies are moving same direction, relative velocity is v2-v1.
After collision two bodies need to separate. It means v2>v1.
The relative velocity is either v2 - v1 or v1 - v2.
The only time you would use v1 + v2 is if those are the speeds (not velocities) of two objects traveling in opposite directions.
Yes.
ehild
  • · Replies 18 ·
  • · Replies 30 ·
