Register to reply
Calculating deflection of a tube
by Mu naught
Tags: deflection, tube
Share this thread:
Mu naught
#1
Jun30-10, 07:41 PM
P: 212
I'd like to calculate the maximum deflection a PTFE tube of 65mm diameter and 5mm thickness. The tube is roughly 3m long and a 1.3m section will be unsupported, I want to know what the maximum deflection the end will experience under it's own weight. I've looked up it's tensile stength which is betweem 10-40 MPa (I don't really understand that unit though)
Could anyone help with this?
Btw, this is not a homework problem this is for a real application.
Phys.Org News Partner Science news on Phys.org
New type of solar concentrator desn't block the view
Researchers demonstrate ultra low-field nuclear magnetic resonance using Earth's magnetic field
Asian inventions dominate energy storage systems
stewartcs
#2
Jul6-10, 09:17 AM
Sci Advisor
stewartcs's Avatar
P: 2,283
Quote Quote by Mu naught View Post
Treat it like any other beam. Roark's is a good reference for the appropriate formula.
CS
Register to reply
Related Discussions
Electron deflection in a cathode ray tube Introductory Physics Homework 7
Calculating max load of square tube (steel) General Engineering 6
Calculating VA in a Tube Preamp Circuit Electrical Engineering 11
Beam Deflection in a Television Tube Introductory Physics Homework 2
Expression for vertical deflection in a cathode ray tube Introductory Physics Homework 0
