Properties of water under high pressure as a function of Temperature
This discussion focuses on the properties of water under high pressure, specifically at 130 bar and temperatures ranging from 30°C to 300°C. The user seeks polynomial equations for material properties such as density, thermal conductivity, dynamic viscosity, and heat capacity at constant pressure, while using COMSOL Multiphysics 3.5. It is concluded that due to water's anomalous properties, reliance on empirical data from resources like the International Steam Tables is recommended over purely mathematical equations.
  • Understanding of thermodynamic properties of fluids
  • Familiarity with COMSOL Multiphysics 3.5 software
  • Knowledge of polynomial equations and their applications
  • Basic concepts of high-pressure fluid dynamics
  • Research the International Steam Tables for water properties
  • Explore empirical data collection methods for fluid properties
  • Learn about polynomial fitting techniques for material properties
  • Investigate the effects of pressure on fluid properties in COMSOL Multiphysics
Researchers, engineers, and students involved in thermodynamics, fluid mechanics, and computational modeling of water properties under varying pressure and temperature conditions.
Conwedge
Hey,
I'm trying to find equations which describe properties of water under high pressure as a function of temperature. The equations are in polynomial form. i am trying to find a better approximation for the material properties of water(density,thermal conductivity, etc...), as the programs description is quite limited. (The program is COMSOL Multiphysics 3.5). Any help or resources you could suggest on this matter would be greatly appreciated.
Thanks
You do not fully list the properties to be considered.
Water has anomalous properties so any serious application will not rely on equations but tables of measurements.
Such tables are freely availbale and are usually called International Steam Tables or similar. Although they are called steam they include properties where the fluid is all liquid at elevated temperature because of the pressure.
Thank you very much for your reply. I'm new to the forum, so Apologies for the lack of information. The properties I am most interested in are:
  • Density,
  • Thermal conductivity,
  • Dynamic viscosity,
  • Heat capacity at constant pressure.
The pressure is 130bar. The temperature ranges from 30°C to approx 300°C.
When you say anomalous, that means that water cannot be accurately described by equations?
So I would have to find properties for a range of temperatures and load its properties this way?
  • · Replies 20 ·
12K
  • · Replies 28 ·
