What is the Proper Length of a Ruler in Motion?
The discussion revolves around the relativistic effects on the length of a ruler in motion, particularly focusing on how its length and angle are perceived from different reference frames. Participants explore concepts related to length contraction, angles, and the implications of relativistic motion in both theoretical and practical contexts.
  • Homework-related
  • One participant presents a problem involving a spacecraft antenna and its angle as seen from Earth, questioning how relativistic effects alter this perception.
  • Another participant suggests using diagrams and formulas to approach the problem, indicating a typical homework strategy.
  • A participant expresses concern about the interpretation of what is seen from Earth, noting that the angle perceived may differ from calculated values due to relativistic effects like Terrell Rotation.
  • There is a request for the correct formula to apply in the problem, leading to a mention of Lorentz contraction.
  • Participants discuss the definition of Lorentz contraction and its application to objects moving at relativistic speeds.
  • One participant describes their approach to a similar problem involving a ruler moving at an angle, expressing confusion about determining the proper length in different frames.
  • Another participant clarifies that length contraction only occurs in the direction of motion and emphasizes that the proper length remains unchanged in the ruler's rest frame.
  • There is a discussion about the proper length of the ruler when viewed from a different frame, with participants debating the implications of angles and components in calculating the contracted length.
Participants generally agree on the concept of proper length and length contraction, but there is disagreement regarding the interpretation of angles and how they affect perceived lengths in different frames. The discussion remains unresolved regarding the specific calculations and interpretations of the angles involved.
Some participants note the complexity of applying trigonometry in this context, highlighting the need for careful consideration of components and angles when dealing with relativistic effects. There are also references to potential errors in calculations, indicating uncertainty in the results.
CollectiveRocker
Here's another one for ya'll. A spacecraft antenna is at an angle of 10 degrees relative to the axis of the spacecraft . If the spacecraft moves away from the Earth at a speed of .70c, what is the angle of the antenna as seen from earth?
Seems to me like a classic homework problem. Try making pictures, find the right formulae and solve. If you get stuck show us what you got, and we'll try to help you.
I don't like the as seen from earth bit. It's straightforward to calculate how the shape in the Earth's frame differs from that in the spacecraft 's frame. However, as seen from earth asks what someone on Earth would see. They certainly don't just see the spacecraft shortened by the relevant factor, rather they see it rotated. I doubt whether the angle they see would agree with that from the calculation.
(Of course there is also the non-relativistic problem that the angle as seen from earth depends on the orientation of the spacecraft .)
Although I am aware of the fact that what an observer will see is different from what is, or can be calculated (I think you are referring to Terrell Rotation?), I think this is not the intent of the question.
What is the correct formula to use for this problem?
The Lorentz contraction.
What is the Lorentz contraction?
An object moving with a speed v can be shown to be contracted in the direction of its motion. The new length in terms of its 'rest length' will be:
[tex]L=L_0/ \gamma[/tex] with [tex]\gamma=\frac{1}{\sqrt{1-v^2/c^2}}[/tex]
This length contraction is called Lorentz contraction. How is it that you do relativistic problems without knowing Lorentz contraction?
So how to I proceed with the problem? Essentially right now, I have two right triangles representing the angles and components. Yet therein lies the problem. How can you use trigonometry is you only know one thing?
Hint: Length is contracted only in the direction of motion.
Hi,
You have a right triangle. The hypotenuse is the antenna. The long side is the ship. The short side is distance from the ship to the antenna perpendicular to the ship. Apply the lorentz copntraction to the long side only. You will then have a new right triangle with the same short side but different long side and hypotenuse. From this you can recalculate the angle.
juju
I'm studying relativity on my own and am having a problem along these lines. The problem I'm doing is similar. I have a ruler that is
moving with a speed .8c relative to a frame S and is 1 m long. First question is no prob, they just ask the length if the ruler is traveling parallel to it's velocity.
Second they ask what is the length if the ruler is moving at an angle of 60 deg as seen from mthe rest frame of the ruler. This was ok too, I just put the ruler as the hypotentuse with 60 degree angle and recognized that only the component of length parallel to the velocity will contract and used the same perpendicular length (since it is unchanged) and thus found the length in this frame.
The third part I'm confused about. They ask what is the length when the ruler makes an angle of 60 degrees with the velocity as seen from S. Now my problem is I'm confused about what length is my proper length in this situation. I definitely don't think it's the intial 1m. It seems to me like it would be the length found in the previous part of the problem, since that is the rest frame of the ruler, and hence it's proper length. But didn't having that length also go hand in hand with a differet angle? So can it still be the proper length in S? What I'm thinking is that I just use this as my proper length, say that only the component of this length parallel to the velocity will contract and thus find the length as seen from S. This is an odd problem in the book so i have an answer, which is .832, where as my answer is .84, but I feel like I'm doing something wrong because for this sort of problem i feel like this is to much error, and that I should have soemthing closer.
Thanks for the help in advance.
Hi,
I think the general idea that you need is this.
There is no contraction if the rulers length is measured by an observer in the rest frame of the ruler. (The ruler does not change length relative to its own frame.)
The length contraction is only measurable by the observer in the frame to which the ruler has a realative velocity.
juju
The proper length of the ruler is its length as measured in its own rest frame: that length does not change. As measured from frame S, that ruler will be a different (shorter) length. Realize that the y-component is not contracted. Now apply some trig and the pythagorean theorem to solve for the measured length of the ruler. (The book's answer is correct.)
  • · Replies 38 ·
  • · Replies 78 ·
  • · Replies 29 ·
  • · Replies 54 ·
  • · Replies 45 ·
  • · Replies 63 ·
  • · Replies 24 ·
