Is a Black Hole the Most Dense Object in the Universe?
The discussion centers around the concept of density in relation to black holes, specifically whether a black hole represents the most dense object in the universe. Participants explore theoretical implications, the limits of current physical theories, and the nature of density in different reference frames.
  • One participant calculates a mass that could create a black hole, leading to a derived density that suggests extreme values, questioning if this is the maximum density possible.
  • Another participant identifies the calculated density as Planck Density, indicating that at such densities, current theories of General Relativity (GR) and Quantum Mechanics (QM) may not apply effectively.
  • Some participants propose that, similar to the speed of light, there might be a limit to density in a given reference frame.
  • Others argue that classical theory does not impose a density limit, as density is coordinate system dependent, allowing for arbitrarily large values in certain systems.
  • Questions arise regarding the definition of point particles and their densities, such as that of an electron, which complicates the discussion of density limits.
Participants express differing views on whether there is a maximum density for objects like black holes, with some suggesting limits based on theoretical frameworks and others asserting that no such limits exist in classical theory. The discussion remains unresolved with multiple competing perspectives.
Participants acknowledge the limitations of current theories in extreme conditions and the lack of experimental data to support claims about density at such scales.
aise0603
Mass falling into a black hole will approach the center of the black hole at a given velocity. As it approaches the center of the black hole, from our reference frame, there is time dialation. In fact, at some given closeness, a unit of Planck time, in the mass's reference frame, is longer than the age of the universe.
Gravitational time dilation outside a non-rotating sphere
to = tf(1-2GM/(rc2))1/2
if to = Planck time
tf = the age of the universe
r = Planck distance
solve for M to find the smallest amount of mass that could possibly create a black hole
Ms = 1.09 X 10-8 kg
Density = Ms/Vs = 6.15718 X 1095kg/m3
Is that the most dense that anything could be in the universe?
What you have calculated is so called Planck Density:
http://en.wikipedia.org/wiki/Planck_units
It means that at such density we can't use GR or QM as is
We need to use more advanced theory which does not exist yet.
But could it be that in a given reference frame, nothing can be more dense than this? Just like nothing can travel faster than the speed of light, in a given reference frame.
In what context do you want us to answer your questions?
As Dmitry mentioned, we have good reason to expect our current theories won't match nature very well in these regimes. And we definitely don't have experimental data from these regimes either. So no "real" answer can be given right now.
But if you are just asking what classical theory like GR says, then the answer is no: there is no density limit. Density is coordinate system dependent, so we can choose a coordinate system which makes it arbitrarily large if we wish. So there is no classical limit on density.
Even ignoring the coordinate system issues, what would you consider a point particle. For example, what is the density of an electron?
Typical...
aise0603 said:
Typical...
Typical what? It was a good answer to your question.
  • · Replies 51 ·
  • · Replies 20 ·
  • · Replies 17 ·
  • · Replies 114 ·
10K
  • · Replies 20 ·
