HP50G Trend Lines: Solve Absorbance vs. Concentrations Easily
  • Context: Calculators
  • Thread starter Thread starter Whalstib
    Lines
The discussion focuses on using the HP50G calculator to perform linear regression for absorbance versus concentration data in chemistry. The user, Whalstib, seeks a straightforward method to obtain the slope (m) and intercept (b) from a series of data points. The correct procedure involves navigating to Stats > Fit Data > Linear Fit, ensuring that X values are entered in the first column and Y values in the second column. Following this method yields the desired linear equation format, confirming that the HP50G can effectively perform the required calculations.
  • Familiarity with linear regression concepts
  • Understanding of data entry in the HP50G calculator
  • Basic knowledge of statistics and trend lines
  • Experience with matrix editing on the HP50G
  • Research how to use the HP50G matrix editor for data entry
  • Learn about different types of data fitting models available on the HP50G
  • Explore advanced statistical functions on the HP50G
  • Study the implications of correlation coefficients in linear regression analysis
Chemistry students, educators, and anyone using the HP50G for statistical analysis and data fitting in scientific experiments.
Whalstib
Hi,
I'm taking 3rd semester chemistry and we often have to take a series of for instance:
Absorbance vs. concentrations data.
Usually a series 5 experiments with the goal to have a spread sheet type answer. I use Excel or what ever I have handy just to find the y=mx + b value for "m".
I want to use my HP50G to accomplish this while in class.
I looked in the HP50G manual and there does appear to be a way to create trend lines but is not working for me. The examples are a bit more involved in the answers.
I have a feeling I'm doing something wrong in the chose of which menu to use... I know my inputs are correct and formatted correctly so either this isn't possible or as I said I'm starting out on the wrong foot.
here's what I've been doing according to the manual:
Stats > Fit data > Linear Fit
I enter the data in A column=x axis, B column=Y axis
Answers not in the format I need.
None of the other choses seem to get me there either..
is there a simple way to do what I'm attempting so I have this with me always?
thanks,
Whalstib
Computer science news on Phys.org
Actually All I'm after is a way to use a linear regression on a series of data points Y vs. X.
Any advise welcome.
Whalstib
Whalstib said:
Hi,
thanks,
Whalstib
STATS > FIT DATA
You should see a screen that shows [tex]\sigma[/tex]DAT, X-Col, Y-Col, and Model. Choose Linear Fit for the Model, and X-Col and Y-Col as 1 and 2, respectively. When entering data, make sure that the X values are listed in the first column, and the Y values are listed in the second column (as per your settings). Here's a sample data set:
(1,5) (2,10) (3,15) (4,20)
On the calculator, this should appear in the matrix editor as as:
1 5
2 10
3 15
4 20
Upon pressing OK, you should see:
[itex]0.+5. \cdot X[/itex]
Correlation: 1.
Covariance: 8.3333333333
This means your "m" is 5. and your "b" is 0.
  • · Replies 73 ·
