Area under the curve problem, but there's a twist
  • Context: Undergrad
  • Thread starter Thread starter relativitydude
    Area Curve
The discussion revolves around a problem related to finding the area under the curve of the function y = x^2, specifically focusing on two areas: area A, which is the integral of x^2 from 0 to a certain value of x, and area B, which is defined by a height h. Participants explore various methods to calculate area B without using the subtraction method from area A.
  • One participant states that area A can be found using the integral of x^2, but expresses difficulty in finding area B without subtracting area A.
  • Another participant suggests making the question more precise and providing an example to clarify the problem.
  • A participant mentions that they cannot find area B by subtracting area A and questions why this method cannot be used.
  • Some participants propose alternative methods, such as expressing the function in terms of y and integrating with respect to y to find area B directly.
  • One participant discusses the possibility of using the inverse function of x^2 to find the area, adjusting limits of integration accordingly.
  • Another participant suggests mirroring the function in the x-axis and adding the height h to the function as a method to find area B.
  • There is a suggestion to reflect the function upon the x-axis and shift it up h units to find area B through integration.
Participants express differing views on the methods to find area B, with no consensus on a single approach. Some participants propose using inversion or mirroring techniques, while others maintain that they cannot use subtraction methods, leading to an unresolved discussion.
Participants mention limitations in their methods, such as restrictions on using subtraction and the need to adjust limits of integration when using inverse functions. The discussion remains open to various interpretations and methods without resolving the mathematical steps involved.
relativitydude
I have a unique area under a curve problem. Say we have a function y = x^2. Ok, so, the area under that curve is just the integral of x^2 from 0 to some value of x. That's easy. Let's call this area A.
Now normally if we wanted to find the area under a height, we would simply mulitply height by the value of x and subtract the integrated form to find the are above the curve to that height. Let's call this area B.
I can't use this method. I can't simply say h*x minus the integral of whatever to find area B. Is there another way to find area B while knowing the function but not involving area A in any way?
try making this confusing question a little more precise. an example could help.
I included a diagram. I need to find area A and area B separately. I can't find area B by subtracting A out of it and conversely I can't find area A by subtracting B out of it.
Why can't you?
Hurkyl said:
Why can't you?
I just cant.
relativitydude said:
I just cant.
Why not? Try it for some value of x and h. What's the problem? On the other hand, maybe you could try expressing the f(x) in terms of y and integrating wrt y instead to find B directly.
PS. What did you use to create the picture? It looks rather neat.
I can't do it the normal way because my problem that this assists boils down to 1=1, a true yet uninspiring finding. I will try it with your suggestions, Ethereal.
That chart? Eh, that's nothing. I made it in Adobe Illustrator. You can draw ANYTHING in that program.
If you found one of them via the integral, couldn't you find the other by subtracting?
I said I can't use the subtraction method.
Do you mean you don't know how? Or aren't you allowed to use it for solving the problem?
If you're looking for another way to find area B, here's a hint:
Think of the line that gives the height as your x-axis and stand on your head.
I am not allowed.
Thanks Gilleo, will do.
wouldn't the inverse function of x^2 have the same area if you integrated along the x-axis and used the height as the upper bound limit?
Here's how
Find [itex]f^{-1}(x)[/itex]. In this case, you are using [itex]f(x) = x^2 [/tex]. The inverse of this function is [itex]f(x) = \sqrt{x}[/itex]. You can now integrate, but make sure to adjust your limits of integration. If you wanted from 0 to 3 of the original function, that would translate to 0 to 9 of the inverse. Just plug in the original limits to the inverse (y) to obtain your new limits.<br /> <br /> Hope this helps![/itex]
I don't know if inversion will help. Inversion mirrors the function in (through?) the line y=x.
My idea was to mirror the function in the x-axis, then add the height h to the function and then integrate. (or alternatively subtract the height from the function and then mirror it).
But the calculation would be exactly the same if you were calculating the area of the rectangle and subtract area A. So it seems silly not to use this method and do use the above method.
Subtract height: f(x)-h
Mirror: h-f(x)
Integrate: [itex]h\Delta x - \int f(x)dx[/itex]
It's the same :)
Well basically it is the same exact thing as what you planed on doing. The area between the function and the y-axis is the same as its inverse function and the x-axis.
ok I'm not sure if anyone mentioned htis but...
lets say the equation was y = x^2... you wanted to find area B
could you not find the integral from 0 -> x by changing the equation ... by flipping it upside down (reflect upon x-axis) and shift it up h units?
thus you get
y = -x^2 + h
and find integral from 0-->x now?
correct me if I'm wrong
  • · Replies 20 ·
  • · Replies 24 ·
