| Thread Closed |
pipe flow rate |
Share Thread | Thread Tools |
| Jul5-10, 05:12 PM | #1 |
pipe flow rate
im trying top find the flow rate of water from a closed pipe.
one thing that i think i can work with is a hose. there is a hose branching of the main flow pipe, which can be used to clean floor etc. im thinking that i can not open the hose and thus measure the stagnatiob pressure at the main pipe. i need help to find a flow rate from this. any ideas???? |
| Jul6-10, 09:22 AM | #2 |
Your problem description isn't clear, can you provide a more coherent explanation or better yet, a schematic/sketch? CS |
| Jul7-10, 07:47 AM | #3 |
totally agree with stewarcts. when the pipe is closed, that mean no flow, no acceleration but u has a volume.
| Jul7-10, 05:26 PM | #4 |
pipe flow rateBut the its algud now, im in talks to put a flow meter on the pipe. so the problems solved, bt thanks anyways. |
| Thread Closed |
| Tags |
| flow rate, pipe flow rate |
| Thread Tools | |
Similar Threads for: pipe flow rate
| Flow rate of water out of a pipe | Mechanical Engineering | 1 | ||
| COMSOL: Periodic inlet flow rate in a pipe | Computing & Technology | 1 | ||
| How to find the flow rate trough a pipe using pressure drop | Classical Physics | 2 | ||
| finding fluid flow rate in a pipe, given pressure difference, length, and diameter | Engineering, Comp Sci, & Technology Homework | 2 | ||
| Transition from pipe flow to open channel flow | Mechanical Engineering | 6 | ||
