| New Reply |
Why does our brain invert the image received from our eyes? |
Share Thread |
| Jul9-10, 10:04 AM | #35 |
| Jul9-10, 10:13 AM | #36 |
Though, I think the developmental story would still be about computation and efficiency (and efficiency pertains to availability), just not among neurons alone, so much as genetic code and protein signaling and the whole complicated set of processes involved in life.
| Jul9-10, 12:14 PM | #37 |
I still haven't worked out why any configuration would require more computation than another. I don't think there is any "right way up" and "upside down" as Dave wrote, just conventions that we've grown used to. Even if our proprioception was inverted with respect to our vision, we would just experience the world like looking in a mirror and that would seem normal to us.
| Jul9-10, 12:34 PM | #38 |
Mentor
| Jul9-10, 12:53 PM | #39 |
Mentor
| Jul9-10, 01:00 PM | #40 |
Try watching tv lsideways or upside down. In the time before you adapt, you might find it somewhat laborious to interpret the screen sideways.
To continue withe the my other analogy, try using a map that's backwards to navigate. It requires an extra step to transform from one coordinate system to another. Even if up and down are just conventions, we still want up on our map to match up in the world, however we define it (wrt gravity most commonly). |
| Jul9-10, 02:31 PM | #41 |
I'm failing to make sense of what many people here are claiming. If we perceived naturally the inverted image it would not make a difference to 'up-down' orientation. It would be normal for us to see that way and this way would still be this way even if to our present normal vision it would be backwards. I do not think there would be any difference in efficiencies... this is just the way we've evolved. If we evolved seeing the world inverted it wouldn't make the slightest difference.
It seems people seem to be thinking that if we pereived things as being inverted we would have to think about what we're seeing in order to know what's going on... what they fail to accoutn for though is that our brains would be acustomed to the 'invertedness' of our vision and it would just be normal. If I wanted to go to the door that is on my left right now my brain would still perceive where the door is relative to my position and I would be able to move as such to get to the door. |
| Jul9-10, 02:33 PM | #42 |
If your vision were to truly be inverted it would be your normal position that everything else is relative to. |
| Jul9-10, 02:35 PM | #43 |
| Jul9-10, 02:36 PM | #44 |
| Jul9-10, 02:40 PM | #45 |
Mentor
| Jul9-10, 02:47 PM | #46 |
It's hard to explain it but the directions are actually relative to us... there is no objective 'up' direction to perceptions. The only thing objective about up is that it is above us... And evolutionary pressure? I assume you are trying to say that all things that happen in biology due to evolution must be a 'good' or 'positive' change? Or that the changes are for the benefit of the organisms? This may very well be true, in regard to our vision, but I do not think any of the reasons listed about computational advantage or efficiencies are involved at all. |
| Jul9-10, 02:54 PM | #47 |
Mentor
Our brains do manipulate up and down in the processing of our vision. The way I first read your objection was that you believe that this correction was unnecessary: that if the correction wasn't made we'd still be able to learn to coordinate motion just as easily as we can with this correction applied. |
| Jul9-10, 02:57 PM | #48 |
If it was normal from the beginning to be 'inverted' then that would mean the new inverted is the old normal. Maybe then we would be thinking about how weird and crazy it would feel to live in a world where we pereived things as inverted (normal to us now) but as far as I can see things look pretty normal!!! EDIT: In response to the added bit, that is exactly my objection with the exception about 'learn to co-ordinate motion'. We wouldn't 'learn' anything it would just be normal, w would do it the same way we do now... because everything we perceive is always relative to us. |
| Jul9-10, 02:57 PM | #49 |
| Jul9-10, 02:58 PM | #50 |
Mentor
...btw, I thought of a good reason why the images need to be corrected: binocular vision. If the image orientation wasn't corrected, then our depth perception and even the overlay of the two fields of view themselves wouldn't work.
| Jul9-10, 03:01 PM | #51 |
Mentor
| New Reply |
Similar discussions for: Why does our brain invert the image received from our eyes?
| about Invert transform | General Math | 1 | ||
| How does eyes encodes information to be sent to brain? | Biology | 5 | ||
| Invert Numbers | General Math | 9 | ||
