| New Reply |
Why does our brain invert the image received from our eyes? |
Share Thread | Thread Tools |
| Jul9-10, 03:05 PM | #52 |
| Jul9-10, 03:17 PM | #53 |
Mentor
Btw, you didn't respond to this: |
| Jul9-10, 03:26 PM | #54 |
What this means though, if I'm right, is that your brain has already overlayed the images correctly and they are already lined up, albeit inversed to how you think you are seeing things. That's my entire point though, if the brain didn't switch things to 'see upright as normal' you would still perceive things as normal, as long as you didn't effect your vision. So if we lost this ability to adjust to perceptions then when we put on those glasses Monique spoke of we would no longer be able to see things as upright anymore, they would permanently look inversed to us and we would have to conciously learn how to function with such vision. This 'correction factor' you talk about does that automatically for us... I think you've mentioned this already a few posts back I just don't agree with it increases efficiency in a normal perceptive state. Things would just look normal all the time... EDIT: didn't see the last prat of your post. I do agree with what you call a correction but I disagree that it is a 'correction' in that there is an objective orientation to the world. It is a correction in the sense that thinking upright is easier for you at all times. But under normal circumstances (without technology to invert our vision) this wouldn't be very useful... things would always still appear normal... unless you held your head in an awkward position for an extended period of time.. For instance: If you put on those glasses which invert the image you see prior to it entering your retina and then your brain adjusts to seeing it as 'normal' does that mean that what you are seeing now is the 'real' normal? No, your brain still just adjusted to the new orientations relative to yourself, and it'll do this for all situations. Without which we would still see things as 'normal' and upright we just wuoldn't be able to adjust to different perspective orientations sub-conciously. |
| Jul9-10, 03:32 PM | #55 |
Mentor
If you built a model of your eye and looked at what was projected on it, you'd see this: [attached] If your brain didn't reorient the images either by switching the left and right images or by rotating both, they wouldn't be overlaid properly. |
| Jul9-10, 03:35 PM | #56 |
Also that's just what is seen in the retina prior to brain processing the information. Uprightness and overlay/depth perception are different processes. If we didn't have the ability to adjust for 'uprightness' we would still process the image overlay etc. That was what I was trying to say earlier .
| Jul9-10, 03:37 PM | #57 |
Mentor
In that case, you are arguing that the brain evolved a function that it doesn't need. Why would it do that? |
| Jul9-10, 03:41 PM | #58 |
Mentor
1. Image hits retina oriented as in the picture I showed. 2. Brain corrects the left/right orientation of the images. 3. Brain stiches the images together. 4. Brain rotates the entire image upright. Now you've added two steps that I thought you were saying were unnecessary. Why doesn't the brain just do this: 1. Image hits the retina. 2. Brain stiches the images together like the picture I showed. Or: 1. Image hits the retina. 2. Brain rotates images upright. 3. Brain stiches images togehter. The first would work, but takes more processing steps. The second wouldn't work at all. The third is most efficient. But you were suggesting upright wouldn't need to be upright. So it could have done this: 1. Image hits the retina. 2. Brain corrects the left-right orientation. 3. Brain stitches the images together (leaving them upside-down). |
| Jul9-10, 03:42 PM | #59 |
Evolution doesn't work base on what's needed or what's better, it just works based on the history of things. I'll have to look further into it to see if there indeed is an evolutionary advantage to the brain adjustment for uprightness but right now I have to go to work :P. I shall respond later.
| Jul9-10, 03:56 PM | #60 |
Here is another interesting article: Right-Side Up - Studies of perception show the importance of being upright
| Jul10-10, 04:27 AM | #62 |
| Aug6-10, 02:12 PM | #63 |
I feel a bit woozy, but think I am dumber now after having read this thread, than before I came. Which isn't easy to do, because I'm fairly stupid to begin with.
Once upon a time, when someone wanted to ask a physics question, they had to take the effort to physically go find someone acknowledged as a physics 'expert' (or, the usual substitute: your local jr. high physics teacher), and if that person wanted to give a more thoughtful answer than whatever came off the top of their head at the moment, they had to physically go to a repository of information (or, the usual substitute: their dusty bookshelf) and consult tomes of peer-reviewed articles, or for more general questions, textbooks. This forced people to invest time in learning, and sometimes, that investment filtered out some nonsense. Now, someone can post an ill-framed question that popped into their head 10 seconds ago, have it seen by thousands, and be responded to by anonymous anyones (like me) with answers that just popped into their own head, or possibly worse, with googled keyword articles. Again, I have to ask, is a useful piece of physics being learned, or do I fundamentally misunderstand the purpose of a physics forum? As for the charge of disrespect: I'll plead guilty, yer honor. Respect me if I give a clear, concise answer with my assumptions defined, terms commonly used and understood, and conclusion relevent to the original question, and I'll do likewise. I genuinely feel bad for sounding like such a curmudgeon, but I can't help but express my disappointment, even if I'm just saying it to myself, and seeing it in print, and inflicting my opinion on other people. ...And so doing no better than what I'm criticizing... |
| Aug6-10, 02:50 PM | #64 |
| Aug6-10, 03:19 PM | #65 |
Hmph forgot to come back to respond to this thread.
1. Image hits retina 2. Image gets assembled correctly (so we see it as one seemless image that is) 3. Image appears 'upright' automatically, it's not 'rotated' it just looks upright because it's normal to see things that way. Point 3 is what I've been trying to point out. It just 'happens' as a 'correction' (I can't think of a better word... it's really not a correction though) So while the image received very well may be inverted our brain forces us to perceive it 'upright' because it's the norm. We are used to observing things in that orientation and this orientation is based on our body. This is honestly a very confusing thing to try and explain... I may be wrong in my thinking but this is just what I've been trying to explain here in this thread. Why is this needed though? That's the OPs question. After reading the article that Monique posted it became clear to me why it would be necessary to make this 'correction'... I don't even know why it never occured to me in the first place, I think someone already mentioned it earlier though. I believe it would be necessary to make this correction in order for things in the outside world to appear upright regardless of our bodies orientation. So if I'm laying down on my side I know where up is still in relation to my bodies normal position. (upright) Sorry for dragging this out if this was what you're original point was russ. I just didn't agree with the efficiency part of consciously thinking where things were, that just didn't make sense to me since it would just be the norm for our brain. |
| Aug6-10, 09:42 PM | #66 |
That's not my cup of tea, so ... I'm moving along... :) |
| Aug7-10, 06:59 AM | #67 |
• G. M. Stratton, Third International Congress for Psychology, Munich, August, 1896 • L.E. White, D. Fitzpatrick, Neuron. 2007 Oct 25;56(2):327-38. • V.S. Ramachandran and D. Rogers-Ramachandran, Scientific American Mind, July 2007 • R. Kalb; D. Solomon, Archives of Neurology, 2007;64(4):485-490. Get out of your little box. |
| Aug7-10, 11:50 AM | #68 |
| New Reply |
| Thread Tools | |
Similar Threads for: Why does our brain invert the image received from our eyes?
| about Invert transform | General Math | 1 | ||
| How does eyes encodes information to be sent to brain? | Biology | 5 | ||
| Invert Numbers | General Math | 9 | ||
