| Thread Closed |
Thermodynamics basics. |
Share Thread | Thread Tools |
| Jul17-10, 06:56 AM | #18 |
Recognitions:
Andy, one counterexample may be sufficient. For an ideal gas, U is a linear function of T only and S can be expressed in terms of T and V (Sackur Tetrode equation). So e.g. T and V are sufficient to specify the state in all respects.
| Jul17-10, 08:18 AM | #19 |
So if you double the depth,the 'h' doubles,so P(pressure) =2(dgh). Intuitively,we could say that the molecules at the depth 2h have to move around with twice the amount of kinetic energy than the molecules at 'h' in order to support the liquid above it. (This is my personal idea...let's see what the experts say!) P.S According to my intuition (that I put forward in the last paragraph),the temperature at the greater depths should be higher,as temperature depends upon the kinetic energy of the molecules....someone told me that this assumption is correct but due to rapid convection currents,we can hardly notice the temperature difference...is that right? |
| Jul17-10, 11:08 AM | #20 |
Recognitions:
Edit: and in any case, your 'counterexample' still has an odd number of state variables, which is the real point. |
| Jul17-10, 02:43 PM | #21 |
If I can shake out the cobwebs and try to remember correctly, in thermodynamics as it's usually taught in undergraduate and graduate courses, it is stated that all information about a thermodynamic system is contained in the relation for a thermodynamic potential--e.g., U(S,V,N1,N2,...) or the various Legendre transforms of this relation (e.g., enthalpy, Gibbs free energy, Helmhotz free energy, etc.). So then the state can be completely specified by 2+n quantities (where n is the number of conserved charges--in textbooks this is usually particle number for n species of particles). Any other quantities can be derived from the thermodynamic potential. Even your arXiv reference appears to say this is true in "classical mechanics", at least for n=0. What has to be true for this not to be the case, and what exactly does it change? Edit: OK, having skimmed the introduction to that arXiv reference, it says it's trying to answer the question. "Is there such a thing as ‘quantum thermodynamics’ where pressure or volume are represented as operators?" This work seems well outside the purview of standard thermodynamics and I believe it needlessly complicates the thread (titled "Thermodynamic basics"). In answering the original question, it's probably best just to state the standard thermodynamics answer: only 2+n quantities must be known to completely specify a thermodynamic system. If I've misunderstood something, let me know. |
| Jul18-10, 09:31 AM | #22 |
Recognitions:
Other than the wiki page on contact geometry, there's some discussion in an appendix of Arnold's "Mathematical Methods of Classical Mechanics". There's a lot available on google scholar, but I'm not able to separate wheat from chaff http://scholar.google.com/scholar?q=...=1&oi=scholart |
| Jul18-10, 11:47 AM | #23 |
So I'll have to stick with my previous answer: in standard thermodynamics you can completely specify a thermodynamic state with 2+n variables, where n is the number of conserved quantities. As an explicit example, from earlier in the thread: Alternately, if you start with T and P, you can use the Gibbs free energy relation G(T,P) to calculate the entropy -S(T,P) = [dG/dT]_P, which you can then plug in for the enthalpy H(S,P). (Again, the enthalpy is related to G by a Legendre transform: H = G + TS). |
| Jul18-10, 11:56 AM | #24 |
I was wondering about linear thermal expansion:If a rectangular plate with a hole in the middle is heated and expands, will the hole get bigger or smaller?
Does the whole thing just scale up (bigger hole) or swell like a donut (smaller)? |
| Jul18-10, 12:41 PM | #25 |
Hello spy and welcome.
You should really start your own thread to ask separate questions, rather than adding to existing ones. It is a good question which probably merits some discussion since there are several possible answers. The short answer is that if the plate is free to expand around its outer edges the hole will also get bigger. |
| Jul18-10, 01:26 PM | #26 |
Thanks for the tip, I'm just new new here. And thanks for a quick reply :)
| Jul18-10, 02:50 PM | #27 |
Recognitions:
I'm not really sure what your point is- when you write H = F + TS + PV or H = G +TS, how can you claim that thermodynamics does not have an odd number of state variables? |
| Jul18-10, 03:30 PM | #28 |
| Jul18-10, 05:09 PM | #29 |
Recognitions:
Since mechanical theories have a symplectic geometry while thermodynamics has a contact geometry, this cannot be the case. |
| Jul18-10, 07:59 PM | #30 |
Mentor
From the paper: http://sgrajeev.com/geometry-of-thermodynamics/ http://www.sci.sdsu.edu/~salamon/MathThermoStates.pdf. The first link is to a blog posting by the author of the paper you cited. This posting works through some standard examples. |
| Jul19-10, 12:42 AM | #31 |
This is made clear in the blog posting (and actually in your arXiv reference as well--see paragraph 4 on page 4). In the case of n=0, there are 5 variables (taken as U,T,S,P,V in these references), but only 2 of them are independent. Adding, e.g., a conserved particle number will add a conjugate pair N and mu (chemical potential) to the total number of variables, but only one of them is independent. |
| Jul19-10, 02:23 AM | #32 |
Recognitions:
Btw, similar equations for U and S are available for non-ideal gasses, e.g. the van der Waals gas: http://en.wikipedia.org/wiki/Van_der_Waals_equation. The equations for U and S only depend on V and T, too, as in the case of the ideal gas. |
| Jul19-10, 08:31 AM | #33 |
Hi everyone!
I'm not sure if this is appropiate,especially with the debate that's going on about one of my questions regarding the number of state variables needed to define the system (I'm waiting for the debate to come to an end so that I get my final answer), however,my teacher taught something really interesting and I'm really curious to know about it. Here's what it is: Well,the Steady Flow Energy Equation (SFEE) basically says that when heat is supplied to to a thermodynamic sysytem or work is done on it,the energy so gained may be stored in the form of internal energy or pdv work( completely thermodynamic properties) or in the form of macroscopic enrgies(like kinetic energy of the fluid as a whole or its potential energy)....now whenever heat is provided to a system,it is supposed to supply kinetic energy to the molecules/atoms thereby increasing the temperature of the fluid. However,according to the SFEE,supplying heat to the fluid in this way could also give kinetic energy to the fluid as a whole too! How is this possible? Similarly,I can't see how the heat supplied to a system could provide potential energy to the entire fluid...I mean heat and flow work(pdV) are supposed to affect the molecules/atoms within the system,not the fluid as a whole! This might have some relation with macroscopic and microscopic internal energies,but I'm not sure. Also,another quick question: When we measure Cp(specific heat at constant pressure),is the process isothermal aswell as isobaric? |
| Jul19-10, 10:33 AM | #34 |
When you heat something up it expands.
This expansion can do work and/or result in an increase in potential energy. But you can't use all the input heat this way. I'm sure you can think of lots of ways this might happen. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Thermodynamics basics.
| Thermodynamics: violation of 1st and/or 2nd law of thermodynamics in a heat engine | Introductory Physics Homework | 7 | ||
| Prof teaches Statistical thermodynamics in a Classical Thermodynamics class | Academic Guidance | 10 | ||
| basics of thermodynamics | Mechanical Engineering | 2 | ||
| basic thermo problem | Classical Physics | 10 | ||
| Thermodynamics basics | Introductory Physics Homework | 3 | ||
