Thread Closed
integration help for expectation of a function of a random variable
Share Thread
Jul9-10, 10:02 PM   #1
Hello,
have a stats question I am hoping you guys can help with. The expectation of a function g of a random variable X is:
E[g(X)] = [tex]\int^{\infty}_{-\infty}[/tex] g(x)fx(x)dx
where fx is the pdf of X. For example, the particular expectation I am considering right now is:
E[g(X)] = [tex]\int^{-\infty}_{\infty}\frac{1}{1+ax^{2}}\cdot \frac{1}{\sqrt{2\pi}}[/tex][tex]e^{-x^{2} / 2}dx[/tex]
this form of integral (i.e. containing that particular e term) must happen often whenever one takes the expectation of a function which depends on a normal random variable. In general, what is the best approach to solve such integrals in closed form here? Integration by parts? I know that the normal curve itself must be integrated using a "trick" such as switching to polar coordinates. Integration by parts might help me isolate the e term to do so, but actually in this case I am not making much progress using that method because the other (first) term has x in the denominator. Any thoughts as to a general approach and/or to this specific problem are much appreciated. thanks!
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Jul10-10, 04:40 PM   #2
[tex]
\frac{d}{dx}[tan^{-1}(ax)] = \frac{a}{1 + a^2x^2}.
[/tex]
Also, since we have [tex] e^{-x^2/2} [/tex], we're going to want a [tex] -x [/tex] in the numerator. We can get this in a crafty sort of way by multiplying by [tex] \frac{-x}{-x} [/tex].
Can you finish from there?
Spoiler
Hint: You're going to have to do an integration by parts within an integration by parts.
Jul13-10, 05:16 PM   #3
Thanks for the response. Sadly, it appears that I am still stuck. I've tried it many different ways, with and without your suggested (-x / -x) term, and keep getting infinitely recursive integration by parts. I am clearly missing something. Might I ask what you are using for "U" in each of your two integrations by parts? Thanks much.
Jul13-10, 11:18 PM   #4
hmm...now that I try it fully, that integral doesn't work out. Are you sure you copied down the problem correctly? If yes, then I'm assuming there's a typo because the answer WolframAlpha is giving is:
[tex] \frac{\pi e^{\frac{1}{2a}} \ \ \ erfc(\frac{1}{\sqrt{2}\sqrt{a}})}{\sqrt{a}} [/tex], where erfc(z) is the complementary error function. It exists and I've read up on its definition; however, unless your teacher has mentioned it in class yet, I doubt it's the correct answer. Most likely, there's an error the problem you stated.
Jul14-10, 09:54 AM   #5
this isn't a homework problem - it's an actual equation I've encountered in a project I'm doing. Anyway, thanks for the response. The answer from Wolfram is helpful - I was getting close to a solution, I think, and perhaps that will get me to it.
Thread Closed
Similar discussions for: integration help for expectation of a function of a random variable
Thread Forum Replies
[Random Variable] [Limits] | P.T. function of a given random variable has a limit Set Theory, Logic, Probability, Statistics 0
Expectation of a function of a continuous random variable Set Theory, Logic, Probability, Statistics 3
Expectation of 2 random variable, E(|X-Y|^a) Precalculus Mathematics Homework 4
Expectation of random variable Set Theory, Logic, Probability, Statistics 9
expectation of random variable is constant? Set Theory, Logic, Probability, Statistics 4
