Thread Closed
Finding Terminal Voltage
Share Thread Thread Tools
Jul12-10, 02:46 AM   #1
In the circuit shown in the figure below the current through the 12.0V battery is measured to be 70.6 mA in the direction shown. What is the terminal voltage Vab
2. Relevant equations
V=E-IR
I1=I2+I3
3. The attempt at a solution
First I set Vab= E-IR= 24 - 10(I1)
I1=I2 + I3
So I applied Kirchoff's rule on the outer loop to find I3
-12 - 10I2 + 20I3 = 0
I3= [12 + 10I2]/20 = 0.6000353 = 0.6A
I1= I2 + I3 = 70.6 mA + 0.6A = 0.6000706A = 0.6A
Vab= 24 -10I1 = 24 - 6 = 18V
Is this right?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Jul12-10, 06:14 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Retired Staff Staff Emeritus
What happened to the 30-ohm resistor?
The voltage due to the internal resistance of the 12-volt battery is (70.6 mA)(10 ohms) = 706 mV = 0.706 V. You seem to have divided by another factor of 1000.
Jul12-10, 09:20 PM   #3
Can I combine the 20(ohm) with the 10(ohm) resistor?
Jul12-10, 11:34 PM   #4
Recognitions:
No, because they're neither in series nor in parallel. You could, however, combine the 20-ohm and 30-ohm resistors because they're in parallel.
Thread Closed
Thread Tools
Similar Threads for: Finding Terminal Voltage
Thread Forum Replies
emf and terminal voltage General Physics 2
terminal voltage Introductory Physics Homework 6
EMF and Terminal Voltage Introductory Physics Homework 13
Emf and Terminal Voltage Introductory Physics Homework 5
