| Thread Closed |
motion with frictional force but without driving force |
Share Thread | Thread Tools |
| Jul16-10, 12:44 PM | #52 |
hm.. i think i know where did i went wrong, i miss out the secant:
[tex] x-x_0=-\frac{m}{\beta}(\ln(\sec(\arctan(v_0\sqrt{\frac{\beta}{ \alpha}})-\frac{\sqrt{\alpha\beta}}{m}t_1))-\ln(\sec(\arctan(v_0\sqrt{\frac{\beta}{\alpha}})-\frac{\sqrt{\alpha\beta}}{m}t_0))) [/tex] |
| Jul16-10, 12:50 PM | #53 |
Incorrect. I suggest you look it up on the web. Just google "Integral Tables" and take your pick.
| Jul16-10, 01:04 PM | #54 |
i have check on the table.. is cosine..
[tex] x-x_0=-\frac{m}{\beta}(\ln(\cos(\arctan(v_0\sqrt{\frac{\beta}{ \alpha}})-\frac{\sqrt{\alpha\beta}}{m}t_1))-\ln(\cos(\arctan(v_0\sqrt{\frac{\beta}{\alpha}})-\frac{\sqrt{\alpha\beta}}{m}t_0))) [/tex] |
| Jul16-10, 01:09 PM | #55 |
Can you make the expression more compact? What is the difference between two logarithms? Also set t0=0 and see what you get.
| Jul16-10, 01:15 PM | #56 |
ok.. the logarithm still can be simplify :
[tex] x-x_0=-\frac{m}{\beta}(\ln(\frac{\cos(\arctan(v_0\sqrt{\frac{\beta}{ \alpha}})-\frac{\sqrt{\alpha\beta}}{m}t_1)}{\cos(\arctan(v_0\sqrt{\frac{\beta}{\a lpha}})-\frac{\sqrt{\alpha\beta}}{m}t_0)}) [/tex] so.. for t0=0.. i will get : [tex] x-x_0=-\frac{m}{\beta}(\ln(\frac{\cos(\arctan(v_0\sqrt{\frac{\beta}{ \alpha}})-\frac{\sqrt{\alpha\beta}}{m}t_1)}{\cos(\arctan(v_0\sqrt{\frac{\beta}{\a lpha}}))}) [/tex] |
| Jul16-10, 01:18 PM | #57 |
Good. I can see the light at the end of the tunnel. Can you? What do you think you should do next?
| Jul16-10, 01:21 PM | #58 |
get rid of the x0 ad substitute the t1?
| Jul16-10, 01:23 PM | #59 |
| Jul16-10, 01:31 PM | #60 |
after the substitution, i get :
[tex] x=-\frac{m}{\beta}(\ln(\frac{\cos(\arctan(v_0\sqrt{\frac{\beta}{\alpha}})-\frac{\pi}{2})}{\cos(\arctan(v_0 \sqrt{\frac{\beta}{\alpha}}))}) [/tex] since [tex] t_1=m(\frac{\pi}{2})\sqrt{\frac{1}{\alpha\beta}} [/tex] should i bother about v0? |
| Jul16-10, 01:34 PM | #61 |
| Jul16-10, 01:45 PM | #62 |
i think i can convert to tangent:
[tex] x=-\frac{m}{\beta}(\ln(\tan(\arctan(v_0\sqrt{\frac{\beta}{\alpha}}))) [/tex] then simplify again: [tex] x=-\frac{m}{\beta}(\ln(v_0\sqrt{\frac{\beta}{\alpha}})) [/tex] |
| Jul16-10, 01:58 PM | #63 |
Note that if you let v0 become very large, you get an infinity. I hadn't appreciated that in the beginning. One thing that bothers me is the negative sign up front. Certainly x must be positive and the argument of the log is greater than 1 especially if v0 becomes very large. Check your integral tables and don't forget that you are integrating
[tex] \int Tan(\delta - t)dt [/tex] There is a negative sign in front of t. Check that and you are done.
| Jul16-10, 02:06 PM | #64 |
hm.. does that mean that the negative sign represent a mistake in the expression?
| Jul16-10, 02:23 PM | #65 |
All I am saying is that
[tex] \int Tan(\delta - t)dt=Log[Cos(t-\delta)] [/tex] |
| Jul16-10, 02:30 PM | #66 |
I shall check back from the beginning the see if any mistake again.. thx for the guidance by the way.. i really appreciate on your help.. Thank you very much :)
| Thread Closed |
| Thread Tools | |
Similar Threads for: motion with frictional force but without driving force
| Driving force of car | Introductory Physics Homework | 1 | ||
| Is frictional force really a force? | General Physics | 12 | ||
| Circular motion : direction of frictional force | Classical Physics | 5 | ||
| Normal Force and Static Frictional Force | Introductory Physics Homework | 1 | ||
| Frictional Force and the AFM | General Physics | 0 | ||
