Is the graviton a different particle from the higgs boson
The discussion centers on the distinction between the graviton and the Higgs boson, exploring their theoretical properties, roles in particle physics, and the implications of their potential existence. Participants examine concepts related to force-carrying particles, mass, and the mechanisms behind the Higgs field and gravitational interactions.
  • Some participants note that the graviton is a spin 2 particle, while the Higgs boson is a spin 0 particle, emphasizing their fundamental differences.
  • It is proposed that the graviton is massless and transmits gravitational force, whereas the Higgs boson, if it exists, is very massive and relates to the generation of mass in other particles.
  • Questions arise about whether the Higgs boson can be considered a force-carrying particle despite its mass, with some suggesting it mediates a force similar to that of the Z boson.
  • Participants discuss the Higgs field's decomposition into a vacuum expectation value and fluctuations that manifest as Higgs bosons, which carry a type of force.
  • There is mention of the lack of experimental proof for both the Higgs boson and the graviton, with some expressing hope for future discoveries at the Large Hadron Collider.
  • Some argue that the graviton is a theoretical construct based on analogies with other fields, and its necessity in nature is questioned.
  • Clarifications are made regarding the relationship between mass, speed, and force-carrying particles, with discussions on the concept of relativistic mass and rest mass.
  • Participants explore the interactions between particles, noting that there is no direct interaction between the photon and the Higgs boson in Feynman diagrams.
Participants generally agree that the graviton and Higgs boson are distinct theoretical entities, but there is no consensus on the implications of their properties or the necessity of their existence. Multiple competing views remain regarding their roles and interactions in particle physics.
Limitations include the theoretical nature of both particles, the dependence on definitions of force and mass, and the unresolved status of experimental evidence for their existence.
filegraphy
I was reading this book that separated the graviton from the higgs boson. Can I get some help anything works for me.
Well, to start, the graviton is spin 2, the Higgs is spin 0.
Then, the graviton is massless, the Higgs (if it exists) is very massive, much more than a proton.
Third, very roughly speaking, the graviton transmits gravitational force,
the Higgs field (related to the Higgs particle) creates or generates the masses in all other massive particles.
All of the above is a little to a lot oversimplified.
Jim Graber
To simplify the above further, yes it is two completely different particles. performing two entirely different parts in particle physics.
So would the Higgs boson be a force carrying particle even if it were massive? What is the function of the Higgs boson? Is the graviton the force carrying particle for gravity?
The Higgs boson would mediate a force of sorts, but no one gives it a name. It's just part of the "Electroweak Force". Its force is similar to that of the "Z boson" (with some technical differences).
And yes, the "graviton" is the particle that mediates the gravitational force.
The Higgs field is "decomposed" into two parts
a) a constant, non-fluctuating classical vacuum expectation value responsible for the masses of W, Z and the fermions
b) the fluctuations around this vacuum expectation value which appear as Higgs bosons carrying a kind of "force" (as blechman said)
They are certainly two separate and different theoretical particles; neither has been proved experimentally. There is hope that the Large Hadron Collider may confirm the existence of the Higgs boson. The Higgs boson is I think the only standard model particle that has not been detected experimentally; gravity is not part of the standard model.
I would add that the Higgs Boson is not required, just the Higgs Mechanism, and as Naty1 pointed out, there is no evidence of it, and certainly no evidence of gravitons. The Higgs would be nice to find however...
Some further remarks:
As nismaratwork said the particle itself is not so relevant, the mechanism of spontaneous breaking of the electro-weak gauge symmetry is what matters. Unfortunately there are no fully viable Higgs-less alternatives, but the community is working on them, just to have a fallback strategy if the LJC disproves the existence of the Higgs.
One must distinguish gravitons and gravitational waves. The latter one are required by GR and there are indirect results indicating their existence. Gravitons are theoretical artefacts based on analogies between quantizing the electromagnetic field (which gives us the photon) and quantizing the gravitational field. It could work that way, but it is also possible that quantizing gravity is totally different from quantizing other fields; therefore this does not necessarily mean that the graviton is required by nature.
So if the Higgs boson were massive, following relativity, it would be a force carrying particle traveling the speed of light causing it to have infinite mass. I thought a massive object cannot travel at the speed of light or else it would have infinite mass. Something is wrong with this picture.
Force carrying particles do not necessarily travel at the speed of light. Just like any other type of particle, that's only if they're massless.
particles traveling at the speed of light do not have infinite mass! you're think of the old and antiquated idea of "relativistic mass" which we no longer use. whenever we refer to "mass" we always mean "rest mass", that is, the energy of the particle when it's at rest:
[tex]E^2=p^2c^2 + m^2c^4[/tex]
So mass is the amount of energy the particle has when p=0.
You can prove that when the mass vanishes (in the sense I am saying here), then the particle is traveling at the speed of light (think photon!). When the mass does NOT vanish, you can prove that it would take an infinite amount of energy to get the particle's velocity up to the speed of light. That's where the "infinite energy" comes in.
also, what he said! :wink:
So the Higgs boson is a massive force carrying particle. It travels less than the speed of light. what force or energy does it carry?
as i said above, it carried a force similar to the force carried by the Z boson. It doesn't have a name, it's just lumped into the "Electroweak force"
The Higgs can turn fermion species into each other; or it can mediate fermion-antifermion annihilation into gauge bosons.
So how are we able to combine the photon (electromagnetic force) with the W and Z bosons (weak nuclear force). Would this create the Higgs boson.
No.
The simplest way to understand how particles interact with each other is to look at the Feynman diagrams. You will see that there is no direct interaction between the photon and the Higgs (no photon-Higgs-vertex).
In principle yes, but its possible you are asking if Santa and the Easter bunny are different people.
Ok thanks. This is making a little more sense now. I appreciate it.
  • · Replies 24 ·
