Square with edges, cube with faces identified.
  • Context: Graduate
  • Thread starter Thread starter Spinnor
    Cube Square
The discussion centers on the identification of edges in squares and cubes to determine the resulting topological spaces. When edges of a square are assigned directions and opposite edges are identified, the outcome is a two-dimensional compact manifold without boundary, which can be classified as a sphere, torus, projective plane, or Klein bottle. The classification of three-dimensional compact manifolds resulting from similar edge orientation assignments in cubes remains an open question, as referenced in Hatcher's survey on three-manifolds.
  • Understanding of compact manifolds without boundary
  • Familiarity with the classification theorem for surfaces
  • Basic knowledge of topological spaces and homeomorphism
  • Awareness of three-manifold theory
  • Study the classification theorem for surfaces in detail
  • Explore Hatcher's survey on three-manifolds for advanced insights
  • Research the properties of the Klein bottle and its construction
  • Investigate the implications of edge orientation in higher-dimensional manifolds
Mathematicians, topologists, and students interested in manifold theory, particularly those exploring the classification of surfaces and three-dimensional spaces.
Spinnor
Say I randomly give each edge of a square a direction and then I identify opposite edges, do I always come up with a two-dimensional compact manifold without boundary? Seems there are eight different edge orientation assignments, many being equivalent? How many different spaces?
Can I do the same with a cube? Give each edge of a cube a random orientation and identify opposing faces? Will we always be able to identify opposite faces with random edge orientation assignments? Can we say anything about such spaces, are any three-dimensional compact manifolds without boundary ?
Thanks for any help!
Assuming your method of gluing does not allow corners, and that you always glue all pairs of edges, yes. The result can be simplified by referring to the classification theorem for surfaces without boundary. Since you are only using one square, the result is either a sphere, a torus, a projective plane, or the connected sum of 2 projective planes (the Klein bottle), up to homeomorphism.
Classification of these objects is still open. See http://www.math.cornell.edu/~hatcher/Papers/3Msurvey.pdf .
  • · Replies 38 ·
  • · Replies 40 ·
9K
  • · Replies 16 ·
10K
