Conceptual question on momentum
The discussion revolves around the concept of momentum in the context of a sprinter starting from the blocks. Participants are exploring whether momentum is conserved when the sprinter generates forward momentum upon pushing off the blocks.
  • Participants are examining the interactions involved when a sprinter pushes off the blocks, questioning whether this action conserves momentum. Some suggest that the Earth and the blocks are part of the system, while others explore the implications of Newton's third law in this context.
The discussion is active, with various interpretations being explored regarding the conservation of momentum. Some participants have offered insights into the role of the blocks and the Earth in the momentum exchange, while others are seeking further clarification on these concepts.
There is an ongoing examination of the assumptions regarding the system boundaries and the forces at play, particularly in relation to Newton's laws. Participants are also considering hypothetical scenarios, such as the effects of the blocks not being secured or the implications of larger blocks.
mizzy
When a sprinter bursts from the starting blocks, he/she generates considerable forward momentum. Is this an example where momentum is not conserved?
I say yes, because there is no interaction of two systems. The sprinter just pushes off and doesn't act on another object.
Am I correct? Can someone help me elaborate this?
thanks
well, if sprinter stands still at first and then gains some speed, then there is a change in momentum. To produce the change in momentum of some body (sprinter in this case) force is needed. But forces always comes in pairs - if some object is pushing sprinter, sprinter must push this object with the same force but in opposite direction (thats Newton's third law). What could this object be? If I'm correct, this object is very very large and massive...
thanks
No. The sprinter just pushes off the starting blocks and hence act on another object which is the starting blocks . Start by defining what is included in the system. Earth, starting blocks, athlete, ..
Let's see if i got this. The system includes the Earth. The sprinter pushes off and exerts a force down on the Earth and therefore generates the forward momentum.
is that a start?
If the sprinter gains forward momentum, and momentum is always conserved, (no overall gain or loss) then something somewhere else must...?
does it have to do with Newton's third law? Something else is pushing against the sprinter?
I'm not good at concepts, and i know it's important to understand in order to do the questions.
please help me understand...THANKS
The questioner is testing your confidence.
He/she is inviting you to make a mistake by handing you the suggestion that 'this is a case where momentum is not conserved'.
What you have to do is to figure out how the sprinter can gain momentum. He has to get it at the expense of some other object.
What would happen if the sprinters blocks were not fastened to the ground properly?
The sprinter is gaining momentum from pushing off the block. If the blocks weren't fastened then he won't be able to push off.
Why?
And what would happen to the blocks?
AJ Bentley said:
Why?
He gains forward momentum when he pushes off from the blocks because he exerts force against it and that generates the momentum.
The blocks would slip.
If momentum is conserved, how can it be 'generated'? It has to come from somewhere or be balanced by a momentum in the opposite direction.
Keep thinking about the blocks. If the sprinter were in outer space when he pushed off from the blocks what would happen to the blocks?
What would happen if he used BIG blocks.
What would happen if he used some REALLY, REALLY HUGE blocks?
What if he had blocks as big as the earth?
The blocks would push back against the sprinter. According to Newton's third law, there is a reaction to an action.
The bigger the blocks, the more force is exerted.
