Thread Closed
Dyna result doesn't match Test result
Share Thread Thread Tools
Jul21-10, 11:15 PM   #1
I try many time to model a simple tensile test for steel MAT_024 but the graph doesn't match from Dyna result and Test result.
Process:
1. Collect data Tensile strain and stress convert to True stress and strain use formula True stress: eng. stress*(1+eng. strain). True strain= ln(1+eng. strain) and then the true strain convert to plastic strain = true strain - (true stress / Young modulus) and plot the graph
2. Use MAT_024 from dyna
3. Then I extract nodout and sec force.
LN1 is left node 1 (triangle on left)
RN1 is right node (triangle on right)
4. Eng stress= Force/Ao and eng. strain= delta Length / original length and plot the graph. (original area is 40, original length is 45mm)
Then the both result was different, why? What the misstake? Anyone can help me solve this problem?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Jul26-10, 11:22 PM   #2
Quote by lambertlai View Post
Process:
May be due to
In dyna or any other software , material is ideal or isotropic.
but in experimentation thats not possible...
so try for more no of samples in experimentation
and go for good homogenous material as possible
Thread Closed
Thread Tools
Similar Threads for: Dyna result doesn't match Test result
Thread Forum Replies
Dyna result doesn't match Test result Engineering Systems & Design 2
Dyna result doesn't match Test result Materials & Chemical Engineering 0
what is the result Set Theory, Logic, Probability, Statistics 2
An unlikely result General Math 5
