Just want to see if my understanding of the photon is correct
  • Context: Graduate
  • Thread starter Thread starter TubbaBlubba
    Photon
The discussion revolves around the nature of the photon, exploring its characteristics in both classical electrodynamics and quantum electrodynamics (QED). Participants examine the differences between these frameworks, the implications of describing photons as point particles versus wave phenomena, and the conceptual understanding of photons in relation to electromagnetic fields.
  • One participant describes the photon as a discrete particle generating an electromagnetic field, with its wavelength affecting potential paths it can take.
  • Another participant argues that the description conflates concepts from electrodynamics and QED, emphasizing that in electrodynamics, a photon is a frequency component of an electromagnetic wave, while in QED, it is a point particle with a probability distribution.
  • Some participants clarify that a photon in classical electrodynamics is physically spread out, contrasting it with the point-like nature of a photon in QED.
  • There is a discussion about whether it is appropriate to refer to photons in classical electrodynamics, with differing opinions on the matter.
  • One participant suggests that the Fourier transform of an electromagnetic field can yield a photon spectral density distribution, while others question the terminology used to describe this concept.
  • Some participants express disagreement regarding the equivalence of photons in QED and electrodynamics, with one suggesting that Feynman diagrams represent interactions in momentum space rather than classical descriptions.
Participants express multiple competing views on the nature of photons in different frameworks, with no consensus reached on the appropriateness of describing photons in classical electrodynamics or the equivalence of photon concepts across theories.
Participants highlight the complexity of the photon concept, noting the dependence on theoretical frameworks and the potential for confusion between classical and quantum descriptions. There are unresolved questions regarding terminology and the implications of Fourier transforms in relation to classical fields.
TubbaBlubba
The photon is a discrete particle, a point, generating an electromagnetic field which fluctuates with a wavelength depending on the energy of the photon. The wavelength also determines the amount of potential paths the photon can take. The wavelike behaviour in the double-slit experiment is accounted for by the fact that the photon can "detect" possible paths before going through them.
Is this a fair explanation?
Science news on Phys.org
No. There are many, many things wrong with it.
A photon in electrodynamics is very different from a photon in quantum electrodynamics. You have the two jumbled together. Furthermore, you seem to be confused on basic quantum mechanics as well, so I wouldn't feel comfortable explaining QED in fine detail.
In electrodynamics, a photon is simply a single frequency component of an electromagnetic wave. It has oscillating electric and magnetic fields. It is spread out through space. It does have a specific wavelength. It can have an arbitrary amplitude/energy.
In QED, a photon is a point-particle. It's location is undetermined, but unlike the above, it's not simply spread out. It's still a point object. It can only have discrete energies, but because it can be in superposition, that only matters as far as absorption and emission go. It also still behaves like a wave, as any quantum object does.
Neither of these "detect" all possible path. They literally take all possible paths at once.
A single photon behaves identically in both descriptions, but when you have a bunch of photons, there are some important distinctions. For example, QED photons may be entangled, while electrodynamics photons are always in a mixed state. This isn't something you need to worry about, though.
Ah, I think I see where you're coming from. Are you saying that the photon in electrodynamics is "spread out" in the same sense that an electron is "spread out" around the nucleus of an atom?
You also can't say that a photon 'generates' an electromagnetic field. It IS the electromagnetic field (or at least vibrations in the field). Waves don't generate water.
No, I'm saying exactly the opposite. Photon in QED is a point-particle that has a probability distribution, like an electron near a nucleus.
A photon in classical electrodynamics really is a wave that is physically spread out.
Okay, so a photon in classical electrodynamics has a "volume" of sorts, and the wavelength is the... Length of the wave? Or is it just a movement in a medium, like a sound wave?
Is it proper to speak of a photon in classical electrodynamics? I think if it as solely a quantum description.
Yeah, just do the Fourier transform of whatever electromagnetic field you happen to have. The spectrum you get is effectively a photon spectral density distribution.
Edit: Just to clarify, say you have E(x,t). Do a Fourier Transform to get E(k,ω). That's your amplitude of photon with wave-vector k and angular frequency ω.
Well I tend to disagree with K^2. IMHO The photon in QFT is the same as in Electrodynamics. The Feynman diagrams are usually in momentum space. The fact that we say "a photon is coming from the left and an electron is coming from the right an they interact" is due to the fact, that the envelopes of the wave packets are so short that it does look like this, but for the cross section calculations it's all plane waves.
I've never seen that called a "photon" in classical electrodynamics. Can you provide a reference to a textbook or journal article or academic website that does this?
OK, "Corpuscle." Is that better? Are you happy now? Lol, don't make me cite my reference, either, lmao...
No. I'd have to dig through tons of material to find someone pointing out this trivial fact. But I'm sure I can find plenty of classical treatments of a vibrating lattice that call the same result for lattice displacement a "phonon" without any quantization. You can probably think of these yourself. It's the same thing.
Isn't this just a transform of the classical field?
After the transform you still have a continuous (I mean classical) field.
  • · Replies 52 ·
  • · Replies 81 ·
  • · Replies 16 ·
  • · Replies 58 ·
  • · Replies 27 ·
