Finding the average energy density of an EM wave in a magnetic field
The discussion focuses on calculating the average energy density of a plane polarized electromagnetic (EM) wave in a magnetic field defined by B = (1,1,0)B0cos(kz-wt), where B0 = 0.001T. The wave propagates in the (0,0,1) direction, perpendicular to the magnetic field. The average energy density is derived using the formula U = B²/μ0, and the electric field is determined to be in the (1,-1,0) direction using the relationship E = cB. The challenge remains in calculating the fraction of energy passing through a polarizer at a 30° angle to the electric field.
  • Understanding of electromagnetic wave propagation
  • Familiarity with the Poynting vector and energy density calculations
  • Knowledge of polarization and polarizer behavior
  • Proficiency in using Maxwell's equations and related formulas
  • Study the derivation of the Poynting vector and its application in energy flux calculations
  • Learn about the relationship between electric and magnetic fields in electromagnetic waves
  • Research the principles of light polarization and how polarizers function
  • Explore the integration of time-varying magnetic fields to find average energy density
Students in physics, particularly those studying electromagnetism, as well as educators and professionals involved in optics and wave mechanics.
Matt S
Hi, I've not posted on here before but I'm trying to keep on top of work over the summer and I'm having some real problems with this question
Consider the plane polarised EM wave in a source free vacuum with magnetic field B = (1,1,0)B0cos(kz-wt) where B0 = 0.001T. Find the direction of propagation of the wave, the average energy density of the wave and the fraction of this energy which would pass through a perfect polaroid sheet at normal incidence if the angle between B and the transmission axis of the polariser is 30o.
For the second part, I'm pretty sure you have to use U=B2/u0 where U is the energy density and u0 is the permeability of free space.
The first part seems relatively simple, the wave travels perpendicularly to the magnetic field, so it moves in the (0,0,1) direction.
The second part asks for the average energy density but since B varies with respect to both time and position I'm not sure how to find it, would I have to integrate the expression for B with respect to t and then use the equation for U?
Obviously without an answer to part two I can't complete the third section. However, I'm pretty sure I have to find the fraction of the wave that passes through the polariser and hence find its energy density and then express that as a fraction of the incident energy density. I'm quite new to polarisation so I don't really know where to start and looking online has just confused me so far. Suggestions or links to relevant material would be really appreciated.
Thanks a lot.
The E field and B field are perpendicular, and both of these are perpendicular to the direction of propagation of the wave. If you can find the E field expression, the Poynting vector (cross product of E and B) will give you the direction of propagation and the energy flux. The gradient of the Poynting vector will give you the energy density.
As far as the polarizer part, I'm pretty sure when they give you transmission axis, that's referring to the electric field and not the magnetic field. So again you need to find which way the E field points and go from there.
Okay, so I used the relationship E=cB to find that the electric field acts in the (1,-1,0) direction and hence that the wave does indeed propagate in the (0,0,1) direction. I then used U=ε0E2 to find that the energy density is U=2c2B02ε0
I'm still confused about the polariser, did you mean that the angle between the magnetic field and electric field is 30o?
  • · Replies 21 ·
