How Is the Spring Constant Dimensionally Analyzed in Oscillation Equations?
The discussion focuses on the dimensional analysis of the spring constant (k) in the oscillation equation T = 2π√(m/k). The key conclusion is that for the equation to be dimensionally correct, the dimension of k must be [mass] / [time]^2. This ensures that when k is multiplied by mass (m) and divided by the square of the period (T^2), the resulting dimensions align with the time dimension on the left-hand side of the equation.
  • Understanding of dimensional analysis
  • Familiarity with oscillation equations
  • Knowledge of basic physics concepts such as mass and time
  • Ability to manipulate algebraic equations
  • Study dimensional analysis in classical mechanics
  • Learn about the derivation of oscillation equations in harmonic motion
  • Explore the relationship between mass, spring constant, and oscillation period
  • Investigate applications of Hooke's Law in real-world scenarios
Students of physics, educators teaching mechanics, and anyone interested in understanding the principles of oscillation and dimensional analysis in physical equations.
lotusbloom
can some1 help me w/this question...like i don't know where to start...thanks in advance
A spring is haning down from the ceiling, and an object of mass m is attached to the free end. The object is pulled down, thereby stretching the spring, and then released. The object oscillates up and down, and the time T required for one complete up and down oscillation is given by the equation T= 2pi square root of m/k, where k is known as the spring constant. What must be the dimension of k for this equation to be dimensionally correct?
Every equation needs to be dimensionally correct, in that the dimensions of the left-hand side must equal the dimensions on the right-hand side.
To your problem:
What's the dimension on your left-hand side?
Obviously, the period T has dimensions "time"!
So, what you need to find out is:
What must the dimension of "k" be in order to gain the dimension of "time" on your right hand side?
Sure, I can help you with this question! It's always a good idea to start by writing down any given information and what you're trying to solve for. In this case, we have the mass m and the time T, and we're trying to find the dimension of k.
To find the dimension of k, we can use the given equation T= 2pi square root of m/k and rearrange it to solve for k. This gives us k= 4pi^2m/T^2. Now, we know that the dimension of k must be such that when it is multiplied by m and divided by T^2, we get a value with the same dimension as time T (since T is on the right side of the equation). This means that the dimension of k must be [mass] / [time]^2.
Hope this helps! Let me know if you have any further questions.
  • · Replies 17 ·
