Toleracing of center distance with internal gear
The discussion focuses on the tolerancing of center distance for internal gears ordered from Rollix, specifically with a center distance of 331.494 mm. The backlash specifications are 0.98 mm at maximum and 0.53 mm at minimum, with a module of 10 and a tooth count of 79 for the bearing and 13 for the pinion. The main issue raised is selecting the appropriate tolerancing grade for the bores to ensure a proper fit with the pinion and bearing shafts. Participants suggest using pitch diameters to layout centers for the bearings and shafts to achieve tangential alignment.
  • Understanding of internal gear mechanics and specifications
  • Knowledge of tolerancing standards and grades
  • Familiarity with backlash concepts in gear systems
  • Experience with pitch diameter calculations and layout techniques
  • Research ISO 286 tolerancing standards for gears
  • Learn about calculating backlash in gear systems
  • Explore methods for determining pitch diameters in internal gears
  • Investigate best practices for aligning shafts and bearings in gear assemblies
Mechanical engineers, gear designers, and manufacturing professionals involved in the design and assembly of internal gear systems will benefit from this discussion.
cherish
Hi all,
first to say sorry if the question is repeated second time
I've order a couple of internal gears from Rollix as picture below:
[PLAIN]http://img155.imageshack.us/img155/5996/centerdistance2.jpg
The calculation from them for internal gears with center distance C=331.494 (mm)
Backslash at center distance maxi: 0.98 (mm)
Backslash at center distance mini: 0.53 (mm)
module of bearing & pinion: m=10
number of teeth: bearing=79, pinion=13
pitch dia: bearing= 790, pinion=130
The trouble now I'm facing is chosing tolerancing grade of center distance on bores to fit with shaft of pinion & bearing, more illustration on picture below:
[PLAIN]http://img293.imageshack.us/img293/3594/74496622.jpg
Does anyone know which of standard can be used to look up or formula to calculate the tolerancing grade of center distance in this case pls give me a help :redface:
Thanks a lot for your reading this asking
The pitch diameters should be tangential.
Use that diameter to lay out your centers for the bearings and shafts.
  • · Replies 30 ·
