OPTICS: Thin Film Interference
The discussion focuses on calculating the angle of a thin wedge formed by two pieces of glass with a strip of paper between them, illuminated by 546-nm light from a mercury-vapor lamp. The interference fringes observed are 15.0 fringes per centimeter, leading to the conclusion that the angle of the wedge is 0.0235 degrees. The analysis involves understanding the phase shifts and the conditions for constructive and destructive interference in thin film optics.
  • Understanding of thin film interference principles
  • Knowledge of phase shifts in wave optics
  • Familiarity with the concept of fringe spacing and its calculation
  • Basic trigonometry, particularly with small angles
  • Study the derivation of the interference condition for thin films
  • Learn about the impact of wavelength on interference patterns
  • Explore the applications of thin film interference in optical coatings
  • Investigate the effects of varying wedge angles on fringe patterns
Students and professionals in physics, particularly those specializing in optics, as well as engineers working with optical devices and coatings.
n0_3sc
Please help:
Two rectangular pieces of plane glass are laid one upon the other on a table. A thin strip of paper is placed between them at one edge so that a very thin wedge of air is formed.
The plates are illuminated at normal incidence by 546-nm light from a mercury-vapor lamp.
Interference fringes are formed, with 15.0 fringes per centimeter.
Find the angle of the wedge.
I have a lot of trouble with Thin Film Interference so a detailed answer will be highly appreciated.
(Answer: 0.0235 degrees)
Science news on Phys.org
phase
Close to the point of touching there are 4 reflected rays ( one from each surface), since the glass is nearly transparent each reflected ray is veryweak BUT about the same intensity.
They occur in pairs two from the upper surfaces (which are in phase) and two from the lower sufaces ( which are also in phase) -- but the second pair are 180 degrees out of phase wrt. the firstpair. ( this is the phase reversal which occurs to to the direction of media density change ).
This means that close to touching the ray pairs cancel each other .
As one departs from the point of contact the difference in the distance traveled by the ray pairs increases and is twice the separation (d) at any point .
The first fringe will occur when the phase shift has increased by 180 degrees = lambda/2 so we can now write
lambda / 2 = 2 . d = 2 . ( x / 2) . theta
where theta is the angle in radians ( assumed small so that tan(theta) ~ theta ) , d is the separation at a point and x/2 is the distance from the touch point . x is the separation of fringes ( and x/2 is the separation of the first fringe from the touch point -- 1/2 a fringe ).
so we have theta = lambda / x / 2 radians = 546 . 10^-9 . 1500 / 2
= .0004095 radians or .02346 degrees.
The reinforcements will fade with distance due the the reflections each only being a few percent each time .
Sorry I could not be of more help.
ray.
  • · Replies 35 ·
