The discussion revolves around the concept of manipulating air flow using charged fields and the potential to create pressure drops over surfaces. Participants explore the feasibility of adding or removing electrons from air molecules to control their movement, particularly in relation to aerodynamic applications. The conversation touches on theoretical and experimental aspects, as well as challenges associated with temperature and energy requirements.
- Exploratory
- Technical explanation
- Debate/contested
- Conceptual clarification
- One participant proposes the idea of adding or removing electrons from air molecules to create charged fields that could move air over a surface at high speeds.
- Another participant mentions that while plasma (ionized gas) could theoretically be used, it would require high temperatures and would quickly neutralize when mixed with air.
- There is a discussion about the Bernoulli effect and whether it could apply to air in contact with a surface, with some suggesting that it could work for any thickness of air layer.
- A participant describes an experiment involving charged electrodes that create an "ion wind," suggesting that similar principles could be applied to the original idea of manipulating air flow.
- Concerns are raised about the energy requirements and temperature issues associated with charging air, with one participant noting that arcs could be problematic.
- Participants discuss the concept of moving positive ions across a surface to produce lift, while acknowledging that plasma manipulation poses significant challenges.
- One participant emphasizes the goal of creating a pressure drop rather than generating thrust, suggesting a method of controlling air movement through selective charging.
- Questions are raised about the necessary speed of air movement to achieve a pressure drop and the maximum pressure drop possible.
Participants express a range of ideas and hypotheses, with no clear consensus on the feasibility or effectiveness of the proposed methods. Multiple competing views remain regarding the practicality of manipulating air flow through charged fields.
Participants acknowledge limitations related to energy requirements, temperature effects, and the complexities of plasma behavior. There are unresolved mathematical considerations regarding the necessary conditions for achieving the desired pressure drops.
