Solving cot pi/4 and sec 5*pi/4
  • Thread starter Thread starter garytse86
The discussion revolves around evaluating trigonometric functions, specifically cotangent and secant, at given angles in both radians and degrees. The original poster successfully computes cot(pi/4) but encounters difficulties with sec(5*pi/4) and seeks assistance in expressing it in surd form.
  • The original poster attempts to solve sec(5*pi/4) by converting it to degrees and expresses confusion about reaching the surd form. Other participants discuss the importance of understanding radians versus degrees and question the assumptions made regarding angle measurement.
Some participants have provided guidance on the conversion between radians and degrees, emphasizing the need to think in radians for advanced mathematics. The original poster later confirms they found the correct answer for sec(5*pi/4), indicating a resolution to their initial confusion.
There is a discussion about the conventions of angle measurement, with participants noting the importance of understanding radians without converting to degrees. The original poster's initial assumption about angle measurement is questioned, highlighting a potential area for further exploration.
garytse86
There are two questions, I can solve the first one but not the second one with the same method.
find the exact value of cot pi/4 in surd form.
cot pi/4
= 1/ tan (pi/4)
= 1 / tan 45 ( in degrees)
= 1 / 1
= 1
which is the right answer according to the book.
However when I tried the next question - sec 5 * pi / 4, there are problems.
sec 5 * pi / 4
= 1 / cos (5 * pi / 4)
= 1 / cos (900/4) ( in degrees)
= 1/ cos(225)
and then I am stuck here. How do I express this in surd form?
The correct answer is minus(2^0.5)
and all I know is cos45 = 1/root2, cos30 = root3/2 and cos 60 = 0.5
Can someone help me get to the correct answer?
sorry people I figured out the correct answer.
1 / cos225
= 1/ cos135
= 1/ cos(180-45)
= 1/ -cos45
= 1/ -1/root2
= minus root2
= - 2^0.5, which is the answer in the book.
Glad you got that straightened out. But I note that you always convert to degrees.
If you are going to continue in mathematics, you should learn to "think" in radians rather than degrees. In advanced mathematics, radians are the "default" measure for angles. (Actually, in advanced mathematics, sine, cosine, etc. are defined independently of angles and the independent variable has no units- to connect them with trig functions of angles you have to assume radians.) In this problem, did the book say "cot(pi/4) radians" or just "cot(pi/4")? If the latter, why did you assume radians? (You were right to do so, I'm just pointing out that you should understand WHY that is right.)
You shouldn't to convert to degrees, you should immediately think "sin(pi/4)= sqrt(2)/2, cos((pi)/4)= sqrt(2)/2" etc.
I am not sure to be honest, but pi is always 180 degrees so I assumed it was in radians? If I am wrong can you please correct me. thanks a lot.
He didn't say that u are wrong.
He only adviced you to get used not to convert in radians.
For example, when you think 45o, it means something to you, if you want to think in radian then pi/4 should means the same to you without converting it to degrees.
It is like if you know two languages, say english and french, and your native language is english (you learned french after english), then it is wrong to translate every french sentence you hear to english in order to understand it, you should understand it directly in french :smile:.
  • · Replies 29 ·
