Differential Equation expression help
The discussion revolves around a differential equation problem where the function f satisfies the equation f'(x)=x√f(x) with the initial condition f(3)=25. Participants are tasked with finding the second derivative at a specific point and writing an expression for the function by solving the differential equation.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss various methods to approach the problem, including substitution and separation of variables. Some express uncertainty about the requirements of part b) and seek clarification on the process. Others share their reasoning and calculations, questioning the correctness of their arithmetic and results.
The discussion is active, with participants sharing their attempts and reasoning. Some have provided guidance on methods like separation of variables, while others are exploring different interpretations of the problem. There is a mix of confidence and uncertainty among participants regarding their approaches.
Some participants indicate a lack of familiarity with differential equations, which may affect their understanding of the problem. There are also mentions of potential arithmetic errors in calculations, highlighting the need for careful verification of results.
Moonflower
Here's the question:
Let f be the function satisfying f'(x)=x[tex]\sqrt{f(x)}[/tex] for all real numbers where f(3)=25.
a. Find f''(3)
b. Write an expression for y-f(x0 by solving the differential equation [tex]\frac{dy}{dx}[/tex] = x[tex]\sqrt{y}[/tex] with the initial condition of f(3)=25.
For a, I got [tex]\frac{x^2}{2}[/tex]+[tex]\sqrt{f(x)}[/tex], so my answer was [tex]\frac{19}{2}[/tex].
For b, I immediately substituted, getting dy/dx=3sqrt(25). then, dy/dx=15 -> dy=15dx -> integrate, y=15x+c, and since the initial condition is f(3)=25, by substitution, C=-20. My answer in the end was y=15x-20.
Am I on the right track? Thanks.
I haven't actually studied differential equations, so I don't know any methods to solve them, and this is coming from my own intuition so I advise you to read with caution :smile:
[tex]\frac{dy}{dx}=x\sqrt{y}[/tex]
[tex]y=\left(\frac{x^2}{4}+c}\right)^2[/tex]
would satisfy this differential.
I don't quite understand what part b) is asking though. Part a) is pretty easy if you know what the function is.
How did you get to that result? It satisfies, but I couldn't reach that result..
Separation of Variables. Also, your expression for the second derivative was correct, but 19/2 isn't so check your arithmetic.
well, 9/2 + 5 is 19/2, or 9.5 isn't it?
Also, can you describe me the process?
thanks.
Ahh foolish me, I put in x=5 rather than x=3, you are correct.
To separate variables, start with [tex] \frac{dy}{dx}=x\sqrt{y}[/tex] and then take over the [itex]\sqrt{y}[/itex] term to give [tex]\frac{1}{\sqrt{y}}\frac{dy}{dx} = x[/tex], then integrate both sides with respect to x.
This part is important to note:
I just realized that to get the square root of the function and have an x multiplied by it, I need a quadratic of the form ax2+c taking all to the 2nd power since we are going to minus one from the power, which is also the square root.
So we have [tex]y=(ax^2+c)^2[/tex] and then [tex]y'=2(ax^2+c).2ax=4ax(ax^2+c)[/tex]
Now we need a=1/4 to satisfy the problem.
Oh and Gib Z's method works much better for those that don't simply notice it! It did take longer to solve, but there, I've learned differentials.
  • · Replies 21 ·
