Algebra Problem: Adding Water to 75% Pure Alcohol to Make 15% Mixture
  • Thread starter Thread starter Omid
    Algebra
The problem involves determining the amount of water needed to dilute a gallon of 75% pure alcohol to achieve a final mixture that is 15% alcohol. The discussion revolves around the formulation of the problem and the underlying concepts of concentration and volume in mixtures.
  • Participants discuss different formulations of the problem, including the original formula and an alternative approach that emphasizes the conservation of alcohol quantity in the mixtures. Questions arise regarding the derivation of the formulas and the meaning of specific variables.
The discussion is active, with participants providing insights into the mathematical relationships involved. Some clarification has been offered regarding the components of the formulas, but questions remain about specific terms and their implications.
Participants are navigating through the assumptions related to concentration and volume, particularly in the context of mixing alcohol with water. There is an acknowledgment of the need for clarity on the definitions used in the formulas.
Omid
How much water must be added to a gallon of alcohol 75% pure to make a mixture 15% pure ?
The book I'm reading has given this formula : 0.75/(n+1)= 0.15 while n is the number of gallons to be added.
I don't understand where the heck the formula comes from :confused:
Can you help me with this problem ?
Thanks
1 * 0.75 = (n+1) * 0.15 seems like a more understandable form to me.
basically, above sais that the (absolute) amount of alcohol is the same in both mixtures.
That formula comes from this one--a more general form:
[tex]C_f(V_1+V_2+\cdots+V_n)=C_1V_1+C_2V_2+\cdots+C_nV_n[/tex]
Where C is concentration and V is volume.
Now, using you original numbers I can do this:
[tex]15\%(1gal+V_2)=75\%(1gal)+0\%V_2[/tex]
Which can be rewritten into the form you first asked about:
[tex].15=\frac{.75}{1gal+V_2}[/tex]
Hope this helped. Good luck.
It clears things up, but what is [tex]c_2[/tex] ?
Thanks
C2 is 0% because pure water has 0% alcohol.
  • · Replies 131 ·
11K
  • · Replies 19 ·
  • · Replies 16 ·
  • · Replies 19 ·
11K
