Why does weighing on carpet make you appear heavier?
  • Context: High School
  • Thread starter Thread starter GummiCandy
The discussion revolves around the phenomenon of weighing oneself on carpet versus solid ground, specifically addressing why some participants perceive a difference in weight readings. The scope includes exploratory reasoning and technical explanations related to the mechanics of weighing scales.
  • Some participants, like GummiCandy, assert that weighing on carpet results in a higher reading, questioning the mechanics behind this observation.
  • Warren and others express skepticism, noting they have not observed such an effect and suggesting that scales may read lower on carpet due to uneven support.
  • Chroot proposes that the scale's design, which may rely on even weight distribution, could lead to inaccurate readings on uneven surfaces like carpet.
  • Some participants, including HallsofIvy, report personal experiments indicating that their scales read lower on carpet, contradicting the initial claim of higher readings.
  • Pete suggests that the way weight is applied to the scale could affect readings, particularly if weight is not evenly distributed when stepping onto the scale.
  • Adam mentions a lecturer's explanation that attributes the discrepancy to the instability of the surface under the scales.
  • Creator humorously speculates about changes in gravitational force as a possible explanation for varying scale readings.
  • A later post suggests that the carpet absorbs some weight, leading to lower readings, but this claim is not universally accepted.
Participants express multiple competing views regarding the effects of weighing on carpet versus solid ground, with no consensus reached on whether the readings are higher or lower on carpet.
Some participants reference personal experiences and anecdotal evidence, while others question the reliability of scales on different surfaces. The discussion includes varying interpretations of how scales function under different conditions.
GummiCandy
I've been struggling with this question for some time now. The question is rather simple. I'm sure most of you people have try weighing yourself on carpet and find out that it's heavier. So, why is that? How come when you weigh yourself on carpet, the measure you get is heavier than if you measure if on solid ground?
Thanks in advance!
I'm sure most of us have never observed any such effect.
- Warren
Thanks in advance!
this question drives me crazy
how can Gummicandy think that most of us have
tried weighing ourselves on carpet?
Gummicandy must be making this up as a clever joke to play on us.
actually Gummi is "rubber" in German so if you give someone
a piece of candy made of rubber that is a practical joke
designed to catch the gullible
it is an inventive scheme in extremely bad taste
That's odd, this is not the first time I have heard this question. The only answer I can think of is that the weight goes through the centre of the scales (where the weighing mechanism is) more, rather than acting through a larger area than it would on a flat surface.
That actually makes sense... the scale is most likely designed with some "feet" on the bottom which are supposed to be placed on a flat surface, and the device is designed to measure the pressure between its top plate and the structural members connected to those feet. If you place the scale on carpet, the scale is supported all over its bottom, not just on its feet -- and it will definitely affect its reading.
On the other hand, it would seem to me that the scale would read low, not high, in such a circumstance.
- Warren
- Warren
Chroot that is the same answer I gave last time, I told them it must be due to some external factor (as an uneven surface would mean that the weight would be acting at a differnet angle to scale reducing it's vector in the direction of the scale), but seening the same question again the only explantion I can think of is that the scal;e is calibrated for weight acting through the surface evenly, but the uneven surface may mean that it acts through the weighing mechanis more than the outer edges.
I know, that's why I said "That [your answer] actually makes sense." Sorry for not quoting you. I was just thinking aloud. :)
- Warren
Using the "scientific method" (heard of it?), I went to my scale on the tile bathroom floor and weighed my self (a truly horrible experience!) then moved the scale to a carpeted floor and weighed myself again. The weight on the carpet was about 8 pounds LOWER, not higher.
- Warren
Hold on. Not so fast. We don't know what kind of scale GummiCandy has.
Here's what I'm thinking: When you step on a scale your weight shifts, i.e. you first put one foot on and then you put the other foot on. A scale may only work properly when the weight is spread evenly over the top. Perhaps what happens is that the matting of the carpet compresses unevenly as the first foot steps on and then when you put the second foot on the scale does not restore to normal.
That's just a quick thought - i.e. not that you *reall* weigh more but that GummiCandy has a weird scale
Pete
Yeah, it means you're not afraid of doing mad things . Weighed myself on my bed. The reading was 5 kg lower than on tiled floor.
EXACTLY...that is what makes sense right? On the carpet part of your weight goes to crushing (no offense ) the carpet, thereby making the apparent, overall weight of the person LESS, not more. Thanks for the 'proof' Ivy!
fizixx
My Mechanics lecturer mentioned this carpet thing as well. He said it was simply the instability of the surface under the scales.
Wow! You mean I was right? Cool! I love it when I take a wild shot and get it right. Thank you for brining this here.
Pete
Very humorous and entertaining posts , I especially liked Halls of Ivy's 'scientific method'.
Unfortunately I am totally unable to participate in the research efforts here. You see, my bathroom scale kept showing a higher reading every several months. So I did what ever good scientist does when appliances go bad...I donated it to the Salvation Army.
However, such a drastic measure was probably premature. I realize now there was another possibility for the higher reading...a change in the value of G !
Creator
- Warren
I don't know about you, but almost all scaling devices in Israel come with the warning "to be used on flat rigid surface only". And ever since I was a child I knew that you had to weigh yourself on the floor only. :)
Then again I also believe in the tooth-fairy, so you never know! ;)
This thread looks to be a bit old, but to put you all out of your misery the reason weighing yourself on carpet gives a lighter result is because the carpet acts as an absorber, thereby taking some of the weight and reducing the load on the scales.
Adam - I hope your mechanics lecturer isn't teaching you anything important!
Amber...
Your post is a little redundant (see my post on page 1), but always good to see reasonable responses to fun questions. :)
f- :wink:
  • · Replies 30 ·
  • · Replies 18 ·
