Could anyone offer some feedback?
I'm reasonably sure I got the gist of it, but I'm not sure how neat a solution it is (i.e. nothing relevant missing, or irrelevancies included). It's a past paper question so I haven't tried to tidy it up.
2. Relevant equations
Hydrostatics/ideal fluid flow stuff.
3. The attempt at a solution
Derived Bernoulli's equation for arbitrary tube of flow then subbed in appropriate variables.
The simplified diagram (I drew an equivalent sketch by hand):
What I wrote:
This is a/the flow tube (not representative of cross section or elevation, includes the reservoir itself) representing the above system.
Assumptions:
Flow is steady streamline (large reservoir, so little change in pressure over short time);
Fluid is inviscid and incompressible.
Other premises (?):
From the assumption of steady flow -> Pressure in the flow tube is constant for any particular position therein (i.e. Pressure
= P(s) for some position s in the flow tube).
The cross section of the flow tube is similarly only a function of position (it doesn't change as a result of pressure etc), so cross sectional area
= A(s).
P(s) >= 0 and A(s) >= 0 for all s.
y1 is the height of the reservoir water;
y2 is the turbine height (=yt);
so y1-y2 = h.
v1,v2 are the velocity of the fluid elements at positions 1 and 2 respectively.
The fluid element moves from position 1 to position 2. The arrows inside the tube represent the internal pressure acting on either "side" of the fluid element producing a force on either side, which will cause some net work (W
d) to be done.
If the force on the left is F
L(s) = P
L(s)A
L(s) and the right is F
R(s) = P
R(s)A
R(s), then
W
d =
integral a to c [P
L(s)A
L(s)] ds -
integral b to d [P
R(s)A
R(s)] ds
integral a to b [P
L(s)A
L(s)] ds +
integral b to c [P
L(s)A
L(s)] ds -
integral b to c [P
R(s)A
R(s)] ds -
integral c to d [P
R(s)A
R(s)] ds
If s
1 = s
2 = s then P
L(s
1) = P
R(s
2) = P(s) [
is something like this too trivial to mention, or better safe than sorry esp. for an exam question that will be ~ similar?]
integral a to b [P(s)A(s)] ds -
integral c to d [P(s)A(s)] ds
More assumptions:
The fluid element is small enough such that the pressure difference across it is ~= 0Pa.
So approximately:
P(a) = P(b) = P
1; P(c) = P(d) = P
Therefore W
d = P
1 integral a to b A(s)ds - P
2 integral c to d A(s) ds
= P
1V
1 - P
2V
Since the fluid is incompressible, V
1 = V
2 = V.
So W
d = (P
1-P
2)V
Density of fluid = D = mass of fluid element / volume of fluid element = m / V; V = m/D
W
d = (P
1-P
2)m/D
= [tex]\Delta[/tex]P
e + [tex]\Delta[/tex]K
e
= mg(y2-y1) + 1/2 m(v
22 - v
12)
(P
1-P
2) = Dg(y
2-y
1) + 1/2 D(v
22 - v
12)
P
1 + Dgy
1 + 1/2Dv
12 = P
2 + Dgy
2 + 1/2Dv
So, having Bernoulli's equation, rearranging for v
22 :
P
1-P
2 + Dg(y
1-y
2) + 1/2Dv
12 = 1/2Dv
The pressures are the gauge pressures, so P
1 = 0Bar.
y1-y2 = h, and v
1 ~= 0ms
-1
Therefore, an expression for the fluid flow velocity at the entrance to the turbine is:
v
22 = -2P
2/D + 2g(h)
The next part of the question is a numeric calculation which gives a value for h and gauge pressure P2 - along with the front matter's values for g and density of water. I reckon I've got the +/- signs alright because v2 increases as h increases, which is expected, and decreases as the back-pressure, P2, increases, also expected. Any feedback would be most appreciated.
In the numeric part of the question, the gauge pressure P2 at the turbines is given as 0.5bar - in a physical system would this pressure above atmospheric be associated with (or at least contributed to by) the resistance of the turbine and connected equipment? If so, would there be a situation where there is maximum energy generated per unit of fluid passing (or transferred from the fluid to the turbine and/or generating equipment ~efficiency?) and also a peak power output (not necessarily under the same conditions as peak energy efficiency)?
