| Thread Closed |
Open command on Fortran |
Share Thread | Thread Tools |
| Aug7-10, 09:41 PM | #1 |
Hello there. I've doing a program that I do not know how many files will be needed, because it'll depend on user's choice. So, how to name them?
I tought that a command like, where n is a user-input number Code:
Do While (i .LE. n) Open (Unit=i, File=i'.dat') i=i+1 EndDo |
| Aug8-10, 06:56 PM | #2 |
I've been thinking about this program (many thanks to emes) and tought thet I could do something like this
Code:
Subroutine Opener (n,i) Implicit None Integer n,i Character (LEN=15) :: files Open (unit=500,File='Files1.dat') Open (unit=501,File='Files2.dat') i=1 Do While (i .LE. n) Write (500,*) i,'.dat' Write (501,*) 'mov',i,'.dat' i=i+1 End i=1 Do While (i .LE. n) Read (500,*) files Open (Unit=i,File=files) Read (501,*) Open (Unit=i+n,File=files) i=i+1 EndDo End Hehe. I've turned this Open problem into a Read one. |
| Aug8-10, 09:18 PM | #3 |
Recognitions:
I have a post somewhere on here as a way to do it. Basically, you can use the WRITE command to concatenate a string with a variable. You can then OPEN the file with the filename as the variable. It's something like this:
Code:
DO i=1,10 WRITE(fname,'I2,A4') i,'.dat' OPEN(10,file=filename,form='formatted') ... END DO |
| Aug8-10, 09:25 PM | #4 |
When I use
Code:
i=1 Do While (i .LE. n) Write (500,*) i,'.dat' Write (501,*) 'mov',i,'.dat' i=i+1 End Code:
1.dat 2.dat 3.dat . . . n.dat Code:
i=1 Do While (i .LE. n) Read (500,*) files(i) Open (Unit=i,File=files) i=i+1 EndDo |
| Aug9-10, 06:04 AM | #5 |
I have solved many issues on this program already, but new ones keep rising.
On this 'subprogram', when it goes into the third loop it can't get out. But it does open all files it should open Code:
Program Lennard2 Implicit None Double Precision dt,e,sigma,x(20),y(20),vx(20),vy(20),tet(20),omeg(20),& rad(20),mass(20) Integer n,i,show Character (LEN=15) :: files(20),files2(20) Call Inserter (dt,e,sigma,x,y,vx,vy,tet,omeg,rad,mass,n,i,show) Call Opener (n,i,files,files2) End Subroutine Opener (n,i,files,files2) Implicit None Integer n,i Character (LEN=15) :: files(20),files2(20) i=01 10 format (i2,A4) 20 format (i2,A7) Open (Unit=500,File="uia.dat",Action='Write') Open (Unit=501,File="duia.dat",Action='Write') Do While (i .LE. n) Write (500,10) i,'.dat' Write (501,20) i,'mov.dat' Write (*,*) 'First Loop' i=i+1 EndDo Close (Unit=500) Close (Unit=501) i=1 Open (Unit=500,File="uia.dat",Action='Read') Open (Unit=501,File="duia.dat",Action='Read') Do While (i .LE. n) Read (500,*) files(i) Read (501,*) files2(i) Write (*,*) 'Second Loop' i=i+1 EndDo i=1 Do While (i .LE.n) Open (Unit=i,File=files(i)) Open (Unit=i+n,File=files2(i)) Write (*,*) 'Third Loop' i=i+1 EndDo i=1 Do While (i .LE. n) Write (i,*) i Write (i+n,*) i+n i=i+1 Write (*,*) 'Forth Loop' EndDo Write (*,*) 'Opener' End Subroutine Inserter (dt,e,sigma,x,y,vx,vy,tet,omeg,rad,mass,n,i,show) Implicit None Double Precision dt,e,sigma,x(20),y(20),vx(20),vy(20),tet(20),omeg(20),& rad(20),mass(20) Integer n,i,show Write (*,*) 'Insert time step' Read (*,*) dt Write (*,*) 'Insert sigma (distance at which the inter-particle & potential is zero)' Read (*,*) sigma Write (*,*) 'Insert epislon (depth of the potential well)' Read (*,*) e Write (*,*) 'Insert steps between output' Read (*,*) show 200 Write (*,*) 'Insert how many particles (2~20)' Read (*,*) n If (n .GT. 20) then Write (*,*) 'Invalid Input' Go to 200 End If If (n .LT. 2) then Write (*,*) 'Invalid Input' Go to 200 End If i=1 Do While (i .LE. n) Write (*,*) "Insert ",i," disk's mass" Read (*,*) mass(i) Write (*,*) "Insert ",i," disk's radius" Read (*,*) rad(i) Write (*,*) "Insert ",i," disk's initial vertical speed" Read (*,*) vy(i) Write (*,*) "Insert ",i," disk's initial horizontal speed" Read (*,*) vx(i) Write (*,*) "Insert ",i," disk's initial vertical position" Read (*,*) y(i) Write (*,*) "Insert ",i," disk's initial horizontal positon" Read (*,*) x(i) Write (*,*) "Insert ",i," disk's initial angular speed" Read (*,*) omeg(i) Write (*,*) "Insert ",i," disk's initial angular position" Read (*,*) tet(i) i=i+1 Write(*,*) 'Inserter' EndDo End |
| Aug9-10, 01:25 PM | #6 |
Recognitions:
You cannot open an array of files in one unit number. Each unit number must correspond to a single file that its operating on. Reading the files in as you described won't work...for several reasons. You can use the same unit number. Just close the file at the end of the do-loop and reopen it after you've changed the filename. After you write out the files, the read would look like:
Code:
DO i=1,n !-- writing routines END DO DO i=1,n WRITE(fname,'A3,I2,A4') 'mov',i,'.dat' OPEN(10,file=fname,form='formatted') !--Read the file here CLOSE(10) END DO Looking through your code it appears you have some issues. Firstly, you have a DO loop where i < n, but n doesn't appear to be defined, nor does it change. Your arrays that hold the data are only dimensioned to 20, but your program is written so that a general number, n, can be called. If you want this, you should change your arrays to ALLOCATABLE. |
| Aug9-10, 01:54 PM | #7 |
I fail to see where I was trying to open twice using the same unit. Could you show me more detailed? On the subject of the array of 20, I've put a few Ifs on Inserter to deal with that, but I'll make some research on Allocatables Arrays, it seems quite interesting.
Code:
. . . 200 Write (*,*) 'Insert how many particles (2~20)' Read (*,*) n If (n .GT. 20) then Write (*,*) 'Invalid Input' Go to 200 End If If (n .LT. 2) then Write (*,*) 'Invalid Input' Go to 200 End If . . . |
| Aug9-10, 09:26 PM | #8 |
Recognitions:
I didn't say that you were opening two files with the same unit number, I said that in your example, you were trying to open an array of files, quote:
Code:
| Thread Closed |
| Tags |
| fortran, open |
| Thread Tools | |
Similar Threads for: Open command on Fortran
| FORTRAN, open several files and read it | Programming & Comp Sci | 20 | ||
| Is there any command in Fortran that is similar to eval in MATLAB? | Engineering, Comp Sci, & Technology Homework | 1 | ||
| open & read command in fortran | Engineering, Comp Sci, & Technology Homework | 0 | ||
| Fortran DO command | Programming & Comp Sci | 4 | ||
