Motion in two or three dimensions
  • Thread starter Thread starter Dekoy
    Dimensions Motion
The problem involves a projectile launched from ground level, aiming to avoid entering a temperature inversion layer at a height h. Participants are tasked with determining the maximum launch speed in terms of h and g, considering the absence of air resistance.
  • The original poster attempts to solve the problem using kinematic equations but expresses confusion regarding the optimization approach and the relationship between variables. Some participants suggest using conservation of energy to relate initial kinetic energy to maximum height, while others explore different equations and substitutions to derive the launch speed.
Participants are actively engaging with the problem, with some confirming the correctness of each other's reasoning. There is a recognition that using conservation of energy simplifies the solution process, although multiple methods are being discussed without a clear consensus on the preferred approach.
There is an indication that the original poster is struggling with the problem setup and the relationship between the variables involved, as well as the potential for different methods to arrive at the same conclusion.
Dekoy
A projectile is being launched from ground level with no air resistance. You want to avoid having it enter a temperature inversion layer in the atmosphere a height h above the ground.(a) What is the maximum launch speed you could give this projectile if you shot it straight up?Express your answer in terms of h and g.
According to me the equation that applies is h(t)=Yi+Vit-(1/2)gt2
I'm lost in this problem I tried doing it as an optimization problem from Calc. I but it just didn't make sense. The other thing I did was solve for Vi in the above equation but it din't give me anything close to the answer in the book I got Vi=(h+4.905t2)/t and the answer in the back is (2gh)(1/2). Any help will be appreciated, Thanks.
Think about it from a conservation of energy perspective, how does the initial kinetic energy relate to the maximum height?
Ok I think I got it, can someone please let me know if this is right or not. This is what I did.
1.(Eq.a)h=Vt-(1/2)gt^2 and from a previous equation found (Eq.b)t=(2h/g)^(1/2)
2.From Eq.a V=[h+(1/2)gt^2]/t
3.Plugging (b) into new (a) gives V=2h/(2h/g)^(1/2)
4.Rationalizing gives V=[2h(2h/g)^(1/2)]/(2h/g)
5.And after solving the division V=g*[(2h/g)^(1/2)]
6.And by properties of exponents V=(2hg)^(1/2) which is the answer in the back of the book.
Any comments will be appreciated in case I did something wrong, Thanks.
Yeah, no, that looks right. But seriously you should really think about this in terms of conservation of energy. It will take 2 lines, max.
Yeah I did it the other way and is way simpler using conservation of energy, oh well now I have two ways of doing it, thanks for the help.
1. a)PE=mgh b)KE=(1/2)mv^2
2. By conservation of energy PE=KE so mgh=(1/2)mv^2
3. m divides out on both sides and you get gh=(1/2)v^2
4. Therefore v=(2gh)^(1/2) which is what i got the other way but way shorter.
I would have never thought about energy being related in this problem on my own thanks zhermes.
  • · Replies 31 ·
28K
  • · Replies 25 ·
  • · Replies 20 ·
