Creating a DC/AC Inverter with Pure Sine Wave Output
The discussion focuses on creating a DC/AC inverter with pure sine wave output using the SG3524 integrated circuit (IC) for PWM signal generation. While the SG3524 is designed for DC-DC switching power supplies, it produces a pulse output that requires extensive filtering to achieve a sine wave. A more effective approach involves using a sine oscillator paired with a robust audio amplifier, particularly for applications demanding high output purity and variable frequency. The design complexity increases with power requirements, necessitating analog output sections to manage significant power dissipation.
  • Understanding of SG3524 PWM signal generation
  • Knowledge of sine oscillator circuits
  • Familiarity with audio amplifier design
  • Basic principles of analog power electronics
  • Research sine oscillator circuit designs for inverter applications
  • Explore audio amplifier specifications and selection criteria
  • Study filtering techniques to convert PWM to sine wave
  • Investigate power dissipation management in analog circuits
Electronics engineers, hobbyists designing inverters, and anyone interested in optimizing DC/AC inverter performance for pure sine wave output.
hisham.i
Hello,
Am trying to make dc/ac inverter with pure sine wave output, while am searching i found an IC which is SG3524 which can generate a pwm signal.
Is it a good choice for pure sine wave output, and what is the difference between the pwm signal generated by micro controller and the pwm generated by this IC in the inverter?
PWM != Sine
The chip you reference is made for DC->DC switching power supplies. It contains all the bits to compare the output voltage with a reference and adjust its PWM output appropriately. The oscillator is probably meant to run at a much higher frequency than typical 50-60Hz power. It has only a pulse output which would need a lot of filtering to extract a decent sine wave.
What you probably need is a simple sine oscillator and a big audio amplifier. The exact design will depend on exactly how pure a sine you need at your output, if the frequency needs to be variable, and how much power you want to draw. The main problem, if you want any significant power, is that the output section will most likely have to be analog. This means that the transistors, or whatever you use, have to dissipate significant power when they are not fully ON -- think of them as continuously variable resistors.
  • · Replies 39 ·
  • · Replies 26 ·
  • · Replies 47 ·
