Thread Closed
Queries on string connections between branes
Share Thread Thread Tools
Sep8-04, 02:46 AM   #1
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>I have questions relating to Brian Greene\'s new book The Fabric of\nthe Cosmos. Specifically, on pg. 390 he shows examples of brane-\nbrane relationships, including how open strings are stuck by their\nendpoints onto their respective branes. In the figure (13.2 b), he\nshows "strings stretching from one two-brane to another".\n\nIn this case the two separate branes (standing in for 3-brane uni-\nverses) are interconnected by open strings, each having one end-\npoint in one brane and the other endpoint stuck in the second\nbrane. I\'d like to know:\n\n1) What kind of particles would match such brane-connecting open\nstrings...ie: bosons (or fermions?) and specifically of *what* sort?\n\n2) Is there any way in which the string itself, stretching between\nits two endpoints (whether both are in the same brane or not),\ncan be seen as analogous to a particle\'s wavefunction (psi)?\n\n3) Since strings have some tension in them, can this be regarded\nas a \'stringy\' tension existing between two distinct brane universes?\n\n4) At least in principle, can two distinct open strings, each having\none endpoint in brane A and one endpoint in brane B, interact such\nthat their two endpoints in brane B, say, unite and thus the two\ndistinct open strings now become one, whose endpoints now live\nentirely in brane A?\n\nAnd is there somewhere on the net or in a book where I can find\nout more detailed information about this? Either popular or tech-\nnical is ok.\n\nThanks,\nGene\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>I have questions relating to Brian Greene's new book The Fabric of
In this case the two separate branes (standing in for 3-brane [itex]uni-[/itex]
verses) are interconnected by open strings, each having one [itex]end-[/itex]
brane. I'd like to know:
can be seen as analogous to a particle's wavefunction [itex](\psi)[/itex]?
as a 'stringy' tension existing between two distinct brane universes?
nical is ok.
Thanks,
Gene
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> A quantum simulator for magnetic materials
>> Atomic-scale investigations solve key puzzle of LED efficiency
>> Error sought & found: State-of-the-art measurement technique optimised
Sep8-04, 09:14 AM   #2
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>On Wed, 8 Sep 2004, Gene Partlow wrote:\n\n&gt; 1) What kind of particles would match such brane-connecting open\n&gt; strings...ie: bosons (or fermions?) and specifically of *what* sort?\n\nDear Gene, it is good that you ask about these open strings stretched\nbetween two different D-branes because they are unusual and "stringy"\n\nSuch open strings can correspond both to bosons as well as fermions. In\nfact, such a configuration of two branes can easily preserve some\nsupersymmetry, and supersymmetry guarantees that each boson has a partner\nfermion and vice versa.\n\nIf the two D-branes are parallel, then the possible quantum numbers (spins\nand charges) of the open string vibrations mimic the usual open strings\nwhose end points terminate on the same D-brane. However, the masses are\nhigher - the string stretched between different D-branes also has a\ncontribution to mass that originates from the mass of the the string -\nwhich must be longer.\n\nIf you imagine that the two different D-branes actually sit on top of each\nother, you won\'t be able to distinguish the string stretched between the\nD-brane #1 and the D-brane #2 from the string stretched between #1 and #1,\nfor example. Nevertheless, the open strings remember where they end - and\ntherefore the corresponding fields created by these open strings carry two\n"Chan-Paton indices" - each index remembers the label of the brane where\none of the endpoints sits.\n\nThat\'s great because these open string fields therefore transform as\nmatrices - in other words, they transform in the adjoint representation of\na U(N) group - or an SO(N) or Sp(N) group if you introduce orientifolds\nwhich make the open strings unoriented (the usual U(N) open strings are\noriented).\n\nThis extension of the open string fields into matrices holds not only for\nthe gauge fields - which means that you will find a U(N) gauge theory\ndescribing dynamics of open strings at low energies - but they also extend\nto the scalar fields that can be found among the open string vibrations.\nThis means that the transverse positions of the D-branes actually form a\nmatrix.\n\nIf you take D0-branes (D-particles), for example, it is no longer true\nthat 5 D0-particles are described by 5 vectors X^i_m where i=1...9.\nInstead, they are described by a 5x5 Hermitean matrix X^i_{mn} where\nm,n=1,2,3,4,5 and i=1...9. You can diagonalize the matrix X^i - with\nrespect to the indices m,n - and the five eigenvalues are the closest\nthing to a "five positions of five D-particles" that you can get. But\ndifferent coordinates cannot be diagonalized simultaneously, and therefore\nthe geometry seen by D0-branes is "non-commutative" in some specific\nsense.\n\nThis extension of positions of objects into matrices is important in\nMatrix theory. You can imagine that the matrices are diagonal and the\ndiagonal entries inform you about the positions, while the off-diagonal\nentries vanish. But these off-diagonal entries are exactly your strings\nstretched between different D-branes. They correspond to massive states\n(by the way, the way how they get their mass is an example of the Higgs\nmechanism, and therefore the off-diagonal excitations are W-boson-like).\nThe massive states can usually be integrated out, but if the two D0-branes\napproach each other, these massive off-diagonal excitations become light\nonce again, and they are important for dynamics.\n\nIn this sense the diagonal entries describe the positions, while the\noff-diagonal entries generate interactions between the objects - but the\nfull dynamics admits no such a canonical decomposition.\n\nThe appearance of matrices and U(N) gauge groups is important elsewhere in\nstring theory. Maldacena\'s AdS/CFT correspondence implies that a U(N)\nsupersymmetric gauge theory in 4 dimensions is equivalent to gravity on\nthe five-dimensional anti de Sitter space. Well, it is really a\nten-dimensional string theory on AdS_5 x S^5. This exotic appearance of\nextra dimension(s) - or holography - is only possible because the gauge\ntheory contains a large number of strongly coupled degrees of freedom, and\nit is only possible because of the large number of open strings stretched\nbetween different branes.\n\nAbove, I tried to describe the case of parallel D-branes. But the two\nD-branes do not have to be parallel, and they do not have to have the same\ndimensionality. A general pair of D-branes leads to a rather general\nstringy spectrum, but we often consider some special configurations, for\nexample open strings stretched between D0-branes and D4-branes (which, by\nT-duality, has many analogous configurations, such as D4-D8).\n\nIn this D0-D4 case, the open strings stretched between the D0 and the D4\ntransform in the bifundamental representation of U(N) x U(M) where M,N are\nthe numbers of D0 and D4 respectively. This configuration preserves some\nsupersymmetry, and therefore the open strings must transform as a\nsupermultiplet. But this D0-D4 supermultiplet is not the usual vector\nmultiplet found on D4-D4 or D0-D0, the multiplet that contains the gauge\nfield. Instead, the open string states arising from D0-D4 are the\nhypermultiplets - something whose bosonic massless contents only contains\nspinless particles i.e. scalars.\n\n&gt; 2) Is there any way in which the string itself, stretching between\n&gt; its two endpoints (whether both are in the same brane or not),\n&gt; can be seen as analogous to a particle\'s wavefunction (psi)?\n\nIt can have an analogous shape as the graph of a wavefunction, but they\nare complete different things. The position of the open string X(sigma) as\na function of the coordinate sigma along the string is a classical shape.\nWell, it can be quantized, but then X(sigma) for each sigma is an\nobservable that can have a well-defined value (eigenvalue). On the other\nhand, the wavefunction psi(x) is a probabilistic object. Psi(x) for a\nspecific position "x" is not what we call "observable" in quantum\nmechanics. Well, if you second-quantize, then Psi(x) becomes a field which\nis observable, and then it *is* analogous to X(sigma) - but there are also\nmany other things in physics which are functions of a real variable. ;-)\n\n&gt; 3) Since strings have some tension in them, can this be regarded\n&gt; as a \'stringy\' tension existing between two distinct brane universes?\n\nStrings do have tension, and these stretched strings indeed do represent a\nforce between the two D-branes. Such a force is not enough to initiate a\nmotion of two *infinite* D-branes, whose mass is strictly infinite, but\nyou could imagine that it can "attract" two D-particles, for example. Yes,\nit can happen, but there are two problems with this idea: one of them is\nthat perturbatively this force is not seen at the leading order because\neven the finite D-branes are very heavy - their tension is proportional to\n1/g where g (the string coupling) is very small. The open strings are very\nloose and light compared to the D-branes, and therefore you must make a\nmore precise calculation to see how their small force can act on the heave\nD-branes.\n\nSecond, if you have D-particles, the total number of oriented strings\nwhose beginning (first endpoint) ends on the D-particle must equal to the\ntotal number of the second endpoints, because a total electric charge\nwould create flux tubes that would have nowhere to go.\n\n&gt; 4) At least in principle, can two distinct open strings, each having\n&gt; one endpoint in brane A and one endpoint in brane B, interact such\n&gt; that their two endpoints in brane B, say, unite and thus the two\n&gt; distinct open strings now become one, whose endpoints now live\n&gt; entirely in brane A?\n\nYes, definitely. For example, a cubic interaction Trace(C.D.E) where C,D,E\nare three fields coming from such open strings is exactly able to convert\nD,E - which can be two open strings stretched between A,B and B,A\n(opposite orientation) to C - which is then an open string stretched\nbetween A and A. Such interactions occur all the time. The open string\nending on the same D-brane can also become a closed string.\n\n&gt; And is there somewhere on the net or in a book where I can find\n&gt; out more detailed information about this? Either popular or tech-\n&gt; nical is ok.\n\nOpen the newsgroup\'s website\n\nhttp://schwinger.harvard.edu/~sps/\n\nand in the right lower corner you will find links to various links and\npopular resources. I might recommend you Zwiebach\'s new book "A first\ncourse in string theory" that is appropriate for the beginners although it\nis technical (written for undergrads). It discusses the strings stretched\nbetween D-branes - in fact, it even constructs the Standard Model with the\nright particles in this setup.\n\nThe standard more advanced textbooks are Polchinski\'s "String Theory" -\nPolchinski is really the main father of D-branes, so be sure that this is\ninformation from the very source of these ideas - and Green, Schwarz,\nWitten, which is however not up-to-date in this direction because the\nD-branes were not known when GSW wrote their book; the only open strings\nthey discuss are those that can end anywhere - in modern terms, they are\nstretched between space-filling D9-branes (in type I theory).\n\nSorry for any typos above, if you find any, I don\'t have time to fine-tune\nit.\n\nAll the best\nLubos\n__________________________________________________________ ____________________\nE-mail: lumo@matfyz.cz fax: +1-617/496-0110 Web: http://lumo.matfyz.cz/\neFax: +1-801/454-1858 work: +1-617/384-9488 home: +1-617/868-4487 (call)\n^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ^^^^^^^^^^^^^^^\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>On Wed, 8 Sep 2004, Gene Partlow wrote:
other, you won't be able to distinguish the string stretched between the
That's great because these open string fields therefore transform as
oriented).
matrix.
that 5 D0-particles are described by 5 vectors [itex]X^{i_m}[/itex] where i=1...9.
Instead, they are described by a 5x5 Hermitean matrix [itex]X^{i_}{mn}[/itex] where
[itex]m,n=1,2,3,4,5[/itex] and [itex]i=1...9.[/itex] You can diagonalize the matrix [itex]X^i -[/itex] with
sense.
string theory. Maldacena's [itex]AdS/CFT[/itex] correspondence implies that a U(N)
ten-dimensional string theory on [itex]AdS_5 x S^5[/itex]. This exotic appearance of
T-duality, has many analogous configurations, such [itex]as D4-D8)[/itex].
In this [itex]D0-D4[/itex] case, the open strings stretched between the D0 and the D4
supermultiplet. But this [itex]D0-D4[/itex] supermultiplet is not the usual vector
multiplet found on [itex]D4-D4[/itex] or [itex]D0-D0,[/itex] the multiplet that contains the gauge
field. Instead, the open string states arising from [itex]D0-D4[/itex] are the
are complete different things. The position of the open string [itex]X(\sigma)[/itex] as
a function of the coordinate [itex]\sigma[/itex] along the string is a classical shape.
Well, it can be quantized, but then [itex]X(\sigma)[/itex] for each [itex]\sigma[/itex] is an
hand, the wavefunction [itex]\psi(x)[/itex] is a probabilistic object[itex]. \Psi(x)[/itex] for a
mechanics. Well, if you second-quantize, then [itex]\Psi(x)[/itex] becomes a field which
is observable, and then [itex]it *is*[/itex] analogous to [itex]X(\sigma) -[/itex] but there are also
D-branes.
> nical is ok.
Open the newsgroup's website
popular resources. I might recommend you Zwiebach's new book "A first
The standard more advanced textbooks are Polchinski's "String Theory" -
Sorry for any typos above, if you find any, I don't have time to fine-tune
it.
All the best
Lubos
__{____________________________________________________________________ ________}
E-mail: lumo@matfyz.cz fax: [itex]+1-617/496-0110[/itex] Web: http://lumo.matfyz.cz/
eFax: [itex]+1-801/454-1858[/itex] work: [itex]+1-617/384-9488[/itex] home: [itex]+1-617/868-4487[/itex] (call)
Sep9-04, 07:15 PM   #3
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>Lubos Motl &lt;motl@feynman.harvard.edu&gt; wrote in message news:&lt;Pine.LNX.4.31.0409080944510.10789-100000@feynman.harvard.edu&gt;...\n\n&gt; If you imagine that the two different D-branes actually sit on top of each\n&gt; other, you won\'t be able to distinguish the string stretched between the\n&gt; D-brane #1 and the D-brane #2 from the string stretched between #1 and #1,\n&gt; for example.\n\nHi Lubos,\nI don\'t know if you just mean difficult to distinguish or impossible to\ndistinguish.\n\n[Moderator\'s note: I forgot to include the word "geometrically" in the\nsentence. Sorry. LM]\n\nIf the latter, would it be safe to say that under certain\nspecial circumstances, a local subset of open strings, all on the\n*same* brane A, might become so dense and oriented that they\ninteract with one another to form a second and essentially inde-\npendent brane B (\'sitting right on top of\' the local region of brane\nA? And if so, would all (or some) of the original open strings now\nbecome interbrane strings, stretched between the old and the\nnew branes? See my reference to black holes below (and I apo-\nlogize for this flight of conjecture.)\n\n[Moderator\'s note: The stringy endpoints sort of remember which branes\nthey end on, even if the branes coincide. If you label the different\nbranes by colors, the endpoints of open strings behave as quarks and\nantiquarks with these colors, and an green quark can always annihilate\nwith an antigreen antiquark. If you just want to produce strings\nstretched between different branes from branes stretched between the\nsame branes only, you can simply revert your previous process and\ngenerate the string between #1 and #2 and the "antistring" between\n#2 and #1 in pairs. LM]\n\n&gt; Above, I tried to describe the case of parallel D-branes. But the two\n&gt; D-branes do not have to be parallel, and they do not have to have the same\n&gt; dimensionality.\n\nA key question for me here is What happens if two higher branes (say\n4-branes for sake of discussion) happen to intersect...either two\nplanar branes, being nonparallel...or two spherical branes? My\nmotivation for asking involves a toy model which, Hawking\'s re-\ncent retraction notwithstanding, posits that every black hole may\nforge a permanent link to a separate, unique baby universe brane,\nwhich proceeds to expand in its own frame \'outside\' of our brane.\n[While this model arguably gives a possible source of \'dark matter\'\ngravitational potential leaking back into our universe, from the\nyounger universes, I refrain from details here.]\n\n[Moderator\'s note: I guess that Hawking would call the intersecting\nbrane an object embedded in the same Universe - baby Universes\nrequire the whole spacetime to have nontrivial topology or be\ndisconnected, not just the branes in it. Let me summarize - I don\'t think\nthat your intuition that intersecting branes are related to baby\nUniverses is correct. I leave the rest for answers to others. LM]\n\nPut simply, one way I model it has our brane being a hypersph-\nerical surface containing, among other things, various black holes.\nEach black hole (BH) is *in* our brane, but centered on any BH\nis a much smaller hyperspherical surface, which is its corres-\nponding baby universe brane. Clearly, this brane surface must\nintersect ours, in a higher dimensional AND M-theoretical sense.\nMy continuing puzzles include:\n\n1) What happens at their intersection (if anything)?\n\n2) What might exist between the BH and the baby brane and\ndoes that also interact with our universe brane (is this one aspect\nof Polchinski\'s wandering psi-waves; see below). I can\'t help won-\ndering if the physics of open strings connecting two branes might\nhelp here. Hence my queries.\n\n&gt; &gt; 2) Is there any way in which the string itself, stretching between\n&gt; &gt; its two endpoints (whether both are in the same brane or not),\n&gt; &gt; can be seen as analogous to a particle\'s wavefunction (psi)?\n&gt;\n&gt; It can have an analogous shape as the graph of a wavefunction, but they\n&gt; are complete different things.\n\nOk, I was shooting from the hip here. :-] A few years ago J.\nPolchinski confirmed my conjecture that while particles them-\nselves are \'stuck\' in their respective branes, their psi wavefunc-\ntions may not be, and they can propagate from one to another\nbrane. I thought that must have interesting implications for par-\nticles living in one brane (say ours) but experiencing the \'ghostly\'\nwavefunctions of identical particles which live in other branes.\nHe told me it was one of the avenues M-theorists were exploring\nthen.\n\n&gt; &gt; 4) At least in principle, can two distinct open strings, each having\n&gt; &gt; one endpoint in brane A and one endpoint in brane B, interact such\n&gt; &gt; that their two endpoints in brane B, say, unite and thus the two\n&gt; &gt; distinct open strings now become one, whose endpoints now live\n&gt; &gt; entirely in brane A?\n&gt;\n&gt; Yes, definitely. For example, a cubic interaction Trace(C.D.E) where C,D,E\n&gt; are three fields coming from such open strings is exactly able to convert\n&gt; D,E - which can be two open strings stretched between A,B and B,A\n&gt; (opposite orientation) to C - which is then an open string stretched\n&gt; between A and A. Such interactions occur all the time. The open string\n&gt; ending on the same D-brane can also become a closed string.\n\nGood...that is what I suspected. Thanks for your time and feedback. I\'ll\ncheck out the other sources you mentioned too.\n\nGene\n\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>Lubos Motl <motl@feynman.harvard.edu> wrote in message news:<Pine.LNX.4.31.0409080944510.10...arvard.edu>...
> for example.
Hi Lubos,
I don't know if you just mean difficult to distinguish or impossible to
distinguish.
[Moderator's note: I forgot to include the word "geometrically" in the
pendent brane B ('sitting right on top of' the local region of brane
new branes? See my reference to black holes below (and [itex]I apo-[/itex]
[Moderator's note: The stringy endpoints sort of remember which branes
> dimensionality.
motivation for asking involves a toy model which, Hawking's re-
which proceeds to expand in its own frame 'outside' of our brane.
[While this model arguably gives a possible source of 'dark matter'
[Moderator's note: I guess that Hawking would call the intersecting
disconnected, not just the branes in it. Let me summarize - I don't think
of Polchinski's wandering [itex]\psi-waves;[/itex] see below). I can't help [itex]won-[/itex]
selves are 'stuck' in their respective branes, their [itex]\psi[/itex] wavefunc-
brane. I thought that must have interesting implications for [itex]par-[/itex]
ticles living in one brane (say ours) but experiencing the 'ghostly'
then.
Good...that is what I suspected. Thanks for your time and feedback. I'll
Gene
Thread Closed
Thread Tools
Similar Threads for: Queries on string connections between branes
Thread Forum Replies
About D-branes in type-II string theory Beyond the Standard Model 8
automobile queries Engineering Systems & Design 2
Cortisol queries Biology 2
String Scattering From Decaying Branes Beyond the Standard Model 7
