Potential difference between two points?
In summary, the question asks for the potential difference between points A and B, where point A is 2cm from the positive plate and point B is 3cm from the negative plate. By using the formula E = d \Delta V, it can be determined that the potential difference between points A and B is 60 volts. This is based on the fact that the plates are 8cm apart and at 160V, there is a 20 volts per centimetre gradient between them. Therefore, the potential difference between points A and B is 60 volts.
bigbird24
This is a question from my highscool gr12 physics class
Q) Two parallel plates are 8cm apart and are appositely charged. The electric potential difference across the plates is 160V. Point A is 2cm from the positive plate, point B is 3 cm from the negative plate.
-What is potential difference between points A and B
My attempt-
Electric field intensity: E=[tex]\Delta[/tex]V/d = 160/0.08 =2000N/C
[tex]\Delta[/tex]Va =E*d ---What value for d do i use?
[tex]\Delta[/tex]Vb =E*d ---What value for d do i use?
[tex]\Delta[/tex]Vab = [tex]\Delta[/tex]Vb - [tex]\Delta[/tex]Va
because you're looking for potential difference you don't need to calculate the reference voltages at a and b independently. What if you just used
[tex]
E = d \Delta V
[/tex]
straight from a to b?
You don't need formulae, you can do it in your head.
The plates are 8cm apart so at 160V there is a 20 volts per centimetre gradient between them.
The points are 3 cm apart so the answer is 60 volts.
thanks AJ, that makes sense to me
= E*(d1-d2)
The potential difference between two points is a measure of the difference in electric potential energy per unit charge between those two points. It is also known as voltage and is represented by the symbol V. In this scenario, the potential difference between points A and B can be calculated by subtracting the potential at point A from the potential at point B. This can be done using the formula \DeltaV = \DeltaVb - \DeltaVa.
To calculate \DeltaVa and \DeltaVb, we can use the formula \DeltaV = E*d, where E is the electric field intensity and d is the distance between the points and the respective plates. In this case, since point A is 2cm from the positive plate and point B is 3cm from the negative plate, we can use d=0.02m for \DeltaVa and d=0.03m for \DeltaVb.
Therefore, the potential difference between points A and B, \DeltaVab, is given by:
\DeltaVab = \DeltaVb - \DeltaVa = (E*d2) - (E*d1) = E*(d2-d1)
Substituting the values, we get:
\DeltaVab = 2000N/C * (0.03m - 0.02m) = 2000N/C * 0.01m = 20V
Hence, the potential difference between points A and B is 20V. This means that for every unit of charge moving from point A to point B, it would gain 20 joules of electric potential energy. This potential difference is a result of the electric charges on the parallel plates and the distance between them.
1. What is potential difference?
Potential difference, also known as voltage, is the difference in electric potential between two points. It is measured in volts (V) and represents the amount of work needed to move a unit of electric charge from one point to another.
2. How is potential difference measured?
Potential difference is measured using a voltmeter. The voltmeter is connected in parallel to the points between which the potential difference is desired. The reading on the voltmeter indicates the potential difference between the two points.
3. What factors affect potential difference?
Potential difference is affected by the amount of charge present, the distance between the two points, and the type of material or medium between the points. It is also affected by external factors such as temperature and humidity.
4. What is the relationship between potential difference and electric current?
Potential difference is directly proportional to electric current, according to Ohm's law. This means that as the potential difference between two points increases, the electric current also increases. However, the resistance of the material between the points can also affect the current.
5. Why is potential difference important in electricity?
Potential difference is important because it is what drives electric current. Without a potential difference, there would be no flow of electric charge and no electricity. It is also crucial in determining the amount of work needed to move charge through a circuit, and plays a significant role in the functioning of electronic devices.
