| Thread Closed |
Has Gravity Probe B been a waste of money? |
Share Thread | Thread Tools |
| Sep10-04, 10:02 AM | #18 |
Has Gravity Probe B been a waste of money?A quick explanation of this aspect of SCC, the details are in the published papers. Two of its principles, Mach and the Local Conservation of Energy yield two solutions of the gravitational field around a static, spherical mass. These converge when r tends to infinity, but slightly diverge in the presence of curvature. This is because the 'Casimir-force' virtual electro-magnetic field contains energy but is not coupled to the Machian scalar field. The harmonisation of these two solutions requires the vacuum to have a small density. In a ‘hand-waving’ explanation: curvature “tries to force the two solutions apart”, but the requirement for consistency between them “draws” energy from the false vacuum, which then becomes observable. This is made up of contributions of zero-point energy from every quantum matter field, which has a natural re-normalised ‘cut-off’ Emax determined, and therefore limited, by the harmonisation of these solutions. 2. I think you know how important GR is within physics and astronomy, the fact that it cannot be reconciled with quantum gravity speaks of both being as yet incomplete, but any replacement must reproduce GR’s successes and therefore reduce to GR in some respect, e.g. GR being its first approximation etc. 3. Looking ahead from SCC’s point of view the crucial question will be to test the equivalence principle by comparing “how particles and photons fall”. (See my thread on the subject). [The experiment would measure how far a horizontal beam of light bends towards a gravitating body as suggested above –and below] As far as the binary pulsars are concerned in SCC; as they are neutron stars their internal matter is relativistic and decoupled from the SCC scalar field force. They therefore behave exactly as in GR. In order to answer your query about the LISA interferometer, which will not detect the difference between GR & SCC, I need first to repeat one property of SCC. In the theory test particles and photons travel on the geodesics of GR. [the presence of the BD type scalar field perturbs space-time but the SCC scalar field force on particles exactly compensates for this] Therefore in SCC the LISA beams behave exactly as in GR. However in my modified LIGO apparatus where the beam is perturbed by the Sun’s gravitational field, or my ‘space interferometer’, in which one half of a split beam is sent around a circular race-track of mirrors for 2km and re-combined with the other split-beam that has traversed just a metre or two, the beam is being compared with physical mass of the apparatus. The SCC deflection of the beam relative to the apparatus towards the gravitating body is tiny, about 1Angstrom, but detectable by the interferometer, of course the GR deflection is null. |
| Sep10-04, 10:57 AM | #19 |
http://www.physicsforums.com/showthread.php?t=37724 http://www.physicsforums.com/showthread.php?t=28868 I am hampered by inadequate math, however and have been mining Citebase for papers that I can understand well enough to connect the dots. Your explanation has been more valuable than months of digging. If SCC is correct, and ZPE is proportional to the difference between the Mach and LCE solutions (which diverge with increasing curvature), then ZPE should be a very strong player in galaxies and galactic clusters, and should be a bear in the vicinity of a black hole. If that is so, black holes should evaporate much more quickly in SCC than as predicted under GR. The real particles created by the capture of their antiparticles by the black hole will be promoted to their "real" states at extremely high energies. Since both members of the virtual particle-antiparticle pair have mass, the black hole will swallow either with no preference. The area outside the event horizon should therefor consist of a mix of real particles and antiparticles at very high energy states, producing some very "interesting" interactions. It seems to me that no black hole can ever appear black under these conditions. Could this be the source of quasar luminosity? As I said above, my math is inadequate to model this. Have you done so, Garth? Thank you again for your explanation! |
| Sep10-04, 11:46 AM | #20 |
astrobiology...search for water...ah, never mind |
| Sep10-04, 12:00 PM | #21 |
| Sep10-04, 02:38 PM | #22 |
have been made. |
| Sep10-04, 02:55 PM | #23 |
The crucial factor would be the difference in the path lengths between the two beams. If that difference is L then the two beams would be displaced relative to each other in a direction towards the Sun by d = (1/4)gsun(L/c)^2 [~ 2 x 10^(-12) m for LIGO] where gsun is the Earth's acceleration towards the Sun, about 1 cm/sec/sec and c the speed of light. LIGO can detect a movement 10^(-18)m longitudinally, but I am talking about a more or less vertical cyclical displacement with a period of 24hrs. |
| Sep10-04, 04:55 PM | #24 |
If the data are analysed wrt different models, can it be concluded that *the data* are consistent with model a, model b, both, neither? (hopefully Yes) When one analyses WMAP data (for example), or SDSS + 2dF data, or distance SNe data, according to SCC, what estimates of the key (free) parameters in SCC does one get? What are the error bars on those estimates? How about a model which incorporates turbo-1's speculation re ZPE? |
| Sep10-04, 06:00 PM | #25 |
However SCC is a freely coasting cosmology in its Einstein frame in which physical processes are best described and already calculated. The freely coasting model does seem to be concordant with the data. I cannot speak of turbo-1's ZPE model but the CIPA site has quite a lot of information about it. Have you seen Eric Lerner's papers on Plasma Cosmology? I am not necessarily advocating any of them but drawing attention to the existence of these other approaches under which the data you mention delivers different conclusions. |
| Sep10-04, 07:48 PM | #26 |
I have been thinking about my "speculations" for years, and have pursued them more vigorously for the past few months. Garth has been working very hard and sticking his neck out for decades. He should not be asked to defend the "speculations" of an amateur in cosmology. Thanks. |
| Sep11-04, 02:09 AM | #27 |
It is a highly determined theory, giving just one model with fixed cosmological parameters that can be interpreted either in its Einstein frame (particle masses conserved), suitable for comparison with observations of physical features of the universe, or its Jordan frame (photon energies conserved), in which gravitational fields and orbits are described. It is therefore highly falsifiable . The surprising thing is though, this determined model does seem to be concordant with observations, although it is not possible to replicate all the work that has been done with the standard paradigm, I could do with some help! What is this determined model? In the Einstein frame it is:- i. A linearly expanding model R(t) = t, it therefore provides the mechanism missing from the work done on the 'freely coasting universe'. Concordant with WMAP data and distant S/N Ia data. The Indian team have done a lot of the required work I mentioned above. Their motivation, starting with Kolb's 1989 paper (Ap.J. 344 543-550 1989 'A Coasting Cosmology') was based on the same insight that started me off developing the New Self Creation Cosmology theory was that in a linearly expanding model the density, smoothness and horizon problems of GR cosmology that Inflation was devised to fix would not exist in the first place, hence Inflation would be unnecessary. (My original paper was Barber, G.A. : 1982, Gen Relativ Gravit. 14, 117. 'On Two Self Creation Cosmologies'.) ii. The curvature constant was +1, the universe was closed, a space-like surface is a sphere. But because of its linear expansion space-time was conformally flat. (In the Einstein frame a time-like slice was a hyper-cone, in its Jordan frame a hyper-cylinder - in both cases slit up the time axis and unroll to a flat sheet.) This may resolve the low frequency problem of the WMAP spectrum (no large angle fluctuations) otherwise resolved by suggestions of a 'football' universe etc. The universe appears flat (as the surface of a cone or cylinder) and yet finite in size. iii. Although the universe is finite in size and space-time is conformally flat its total density parameter is only 1/3, 0.33. If this seems inconsistent remember the Friedmann equations have changed because the basic GR field equation has changed; (change the theory and the observations using that theory change etc. etc.) There is no need for Dark Energy. iv. The density parameter of the zero-point energy, the false vacuum is determined by the SCC field equations to be 1/9, 0.11. v. The density parameter of the rest is therefore 2/9 or 0.22. The freely coasting model suggests baryon density to be 0.20 and not 0.04 so there is no need for Dark Matter. The neutrino density now appears to be about 0.01 – 0.02. (New Scientist 4 Sep 04 pg 39 "Weighing the invisible") So the inventory of the universe is more or less complete! I am not sure of the SCC solution for a Black Hole and therefore cannot say what happens in severe curvature nor have I been able to study the Sloan Digital Sky Survey with respect to the theory, there is a lot of work still to do, nevertherless I am not discouraged and await GPB - which as you can imagine I do not think is a waste of money! - Garth |
| Sep11-04, 01:57 PM | #28 |
Garth, SCC predicts that photons fall at 3/2 the speed that particles fall in a gravitational field, breaking that GR equivalence. Is there a similar prediction in SCC that antimatter would fall faster than matter in a gravitational field, thereby breaking the gravity/inertia equivalence in the presence of mass?
You can probably see where I'm going with this...a mechanism whereby the ZPE field is aligned (curved) by matter, with the anti-particle of each virtual pair more strongly drawn toward nearby matter than its particle partner. If matter causes the virtual pairs in the quantum vacuum surrounding it to arise in a preferential orientation, there is a simple mechanism to explain space-time curvature, and gravitation might be explained without the need for the Higgs fields, gravitrons, etc. That gravity arose from the interaction of matter with the fields of the quantum vacuum was proposed by Andrei Sakharov almost 40 years ago (and more recently followed up by the CIPA group and others). I have not found in any of their papers a plausible mechanism for the interaction, except some rather unhelpful references to the Davies-Unruh effect. A differential in the matter/anti-matter fall rate would do the trick. Anyway, I have been searching the web looking for any on-going experiment to test the fall rate of antimatter in a gravitational field, but have found only proposals and no conclusive results. The arrival times of neutrinos and anti-neutrinos from SN1987A have been cited as evidence that the fall rates are essential equivalent, but neutrinos and anti-neutrinos are so weakly interactive that their fall rates might be statistically equivalent anyway. The are chargeless and they only react to the weak force, and so would not behave in the same manner as the basically EM particle/anti-particle virtual pairs of the ZPE field. |
| Sep11-04, 04:13 PM | #29 |
turbo-1 - An interesting question... hmmm...thank you.
In SCC there would appear to be no difference in the way matter and anti-matter react to the gravitational field. The differences are to be found when the internal pressure becomes significant. Actually photons obey the equivalence principle, it is slow moving particles that experience an upwards scalar field force, which decouples as the pressure increases to 1/3density c^2. Unless the internal pressure of anti-matter is different to that of ordinary matter there would be no difference. The false vacuum on the other hand experiences anti-gravity of 1/2g..makes you think... Garth |
| Sep11-04, 05:21 PM | #30 |
| Sep11-04, 05:27 PM | #31 |
To clarify, I was trying to say that the proponents of *any* approach (other than 'the concordance model') could be asked to provide estimates of the (free) parameters in their model(s), as determined from analysis of (publicly available) astronomical datasets. IOW, don't just 'tell us what your theory is', also tell us what 'analysing the best available data, we find that our model is consistent, and estimates of the key parameters are {list, inc error bars, with a statistical metic}.' |
| Sep11-04, 05:34 PM | #32 |
I'll drink to that ! Garth
| Sep12-04, 01:37 AM | #33 |
Garth, I appreciate the effort you have put into SCC. I read your paper and it is interesting. I still think the biggest problem you face is that SCC predicts a universe that forms too early and collapses before stars and galaxies can form. Can you reform your model that explains how the universe behaves now? I think not. The model Nereid suggests has observational evidence. In fact, she has a mountain of evidence in her favor.
| Sep12-04, 06:22 AM | #34 |
That may ultimately be a proper model, but it left me wondering what would cause the "opposites attract" approach to work, aside from "force acting over a distance". That led me to the notion that the fall rate of antimatter in a gravitational field might be higher than that of matter. We really need a definitive test of the fall rate of antimatter - the CERN data were inconclusive.That bit of asymmetry could polarize the ZPE field in the presence of large masses. It could perhaps explain a few other things. One implication for such virtual-pair alignment in the process of black hole "evaporation" would be that the black hole would capture more anti-particles than particles. That would result in more particles than anti-particles being promoted from virtual to "real" status outside the event horizon. After the inevitable (and very energetic) annihilation events near the event horizon, there would remain a net excess of new real particles to form matter (after they cooled from the ultra hot plasma state!). This is probably not going to be testable in any real sense, unless quasars are what we see when black holes behave this way. As an extension: We see matter all around us, not anti-matter. Assuming that the universe began with equal proportions of each, could this black-hole behavior be a model for how anti-matter and matter were separated? If so, beyond the event horizons of these massive objects would be domains dominated by anti-matter. Lee Smolin has described our Universe as one fine-tuned to produce black holes (a rational alternative to the anthropic principle!), and he speculated that a prospective inhabitant of the universe in a black hole would look out through his universe's past toward a singularity, much as we view our universe in standard cosmology. I can't find that paper, now, but I'm pretty certain he didn't cite a matter/antimatter selection effect. To go one step farther out on the limb , these antimatter "universes" should all have equivalent black holes that preferentially eat matter, creating nice matter-rich pockets like the one we live in. Yep, it's turtles all the way down.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Has Gravity Probe B been a waste of money?
| Gravity probe-B | Special & General Relativity | 36 | ||
| Gravity Probe B | Cosmology | 3 | ||
| Gravity Probe B | Special & General Relativity | 2 | ||
| gravity probe b | Special & General Relativity | 1 | ||
