Question about velocity and motors
  • Thread starter Thread starter _FES_
    Motors Velocity
The discussion revolves around calculating the maximum velocity of a motorized system designed to move a 159 kg mass across a horizontal plane. Participants explore various factors affecting the calculations, including torque, power, gearing, and the effects of friction and inertia.
  • Homework-related
  • One participant outlines the specifications of a motor, including torque, speed, power, gearing, and inertia, and seeks help in calculating maximum velocity.
  • Another participant suggests using the formula for kinetic energy to find velocity but expresses uncertainty about integrating motor speed and gearing into the calculations.
  • A later reply clarifies the gearbox and pulley setup, providing a formula for calculating the pulley's RPM and torque based on the motor's specifications.
  • One participant proposes a simplified approach to the problem, considering maximum force, acceleration, and the relationship between RPM and gear speed.
  • Another participant emphasizes the need for a more detailed response, indicating urgency due to a deadline for a work-related task.
Participants do not reach a consensus on the best approach to calculate maximum velocity, and there are multiple competing views on how to integrate various factors into the calculations.
Some assumptions remain unaddressed, such as the efficiency of the system and the exact impact of friction and inertia, which could affect the calculations. The discussion also lacks clarity on how to incorporate RPMs into the final velocity calculation.
_FES_
I'm working on choosing an appropriate motor. I have the calculations I need for the required torque, power, max velocity, force, and acceleration. Now I need to know the maximum velocity that a specific motor can move 159 kg 0.45 m across a horizontal plane.
In all of my calculations for which motor was needed, I neglected to take friction and inertia into consideration because I did not need to be so exact. The friction is quite minimal anyway. It is a seat moving along a metal rail.
The motor specs are as follows:
Torque - 0.304 Nm
Speed - 4000 RPM
Power - 0.13 kW
Gearing - 60:1 (15*4)
Inertia - .031 kg-cm^2
I don't yet know what the radius of the gear attached to the gearbox will be. I imagine something like 5 cm. I was told that the equation would involve something like (2pi*r(RPM))/15, but I don't know how that will work in with the power, mass, and distance when calculating the max velocity.
I was thinking if using 1/2*130*0.45 would be possible to use for the kinetic energy and then solve for v with 29.25=1/2*159*v^2. But again, I'm not sure how to work in the Speed and gearing of the motor.
I appreciate the help. If I'm missing any info, let me know.
Does anyone at least have some tips or ideas?
Thanks
Update:
Gearbox is 15:1. Pulleys are 1:1.
Radius of pulley is 1"
The pulley's RPM speed is (circumference*RPM)/gearing, right? In other words, (2pi*4000)/15=1676 RPM. The torque would then be 0.304*15=4.56 Nm.
So then how do I get the maximum velocity of the 159 kg along 0.45 m that this setup can provide?
Hi FES, if this is your homework, it should go to the homework section.
Add a sketch or drawing if possible.
Think different, if you had to lift the same mass 0.45m in the vertical plane, frictionless and disregarding inertia, how would you solve the problem ? What would be the acceleration and kinetic energy ? And the maximum vertical speed ?
Now turn back to the horizontal plane and consider friction and inertia, what top speed would be attainable considering also the transmission efficiency?
Hi John,
Thank you for your response. No, this is not homework, this is real-world for my job. I simply am unfamiliar with working with motors and have not done physics in several years, so I am having a mental block. Unfortunately, I cannot disclose this device, but think of those Concept 2 rowers you would find in a gym.
I am running out of time. The motor guy will be in on Monday and I must have a spreadsheet complete with this same calculation for every motor in a certain class by then for my CEO.
Ergo, if you wouldn't mind feeding me a bit more than a crumb, I'd greatly appreciate it. I am thinking what I need to do is use Force=torque/radius and find the acceleration from there with F/m.
4.56 Nm/.0254 m=179.53 N
179.53 N/159 kg=1.13 m/s
1.13*0.45 m=0.51 s
Do the RPMs still need to factor in somewhere?
Thank you.
It looks like this is a gear\rack mechanism, a very simplified approach will be:
Considering the mass path is perfectly horizontal, negligible rotational inertia, no friction, starting at max power and max rpm...
Fmax = Tin x i x n / r
F -> Max Traction Force [N]
Tin -> Motor Input Torque [N.m]
i -> Gear ratio
n -> Efficiency
r -> Gear Radius [m]
amax = Fmax / m
amax -> Max Acceleration [m/s²]
m -> Mass
converting rpm -> rad/s => 1 RPM = 2*PI / 60s
w2 = w1 / i
w2 -> Gear speed [rad/s]
w1 -> Motor speed [rad/s]
vmax -> w2 x r
vmax -> Maximum Travelling Speed [m/s]
tmin = (2 x d / amax)^0.5
tmin -> Minimum Acceleration Time
d -> Travelling Distance [m]
P = Fmax x vmax / n
P -> Power [W]
I typed up a lengthy reply that failed to post and is now lost, so all I will say is thank you for all of your assistance, John. I'm grateful!
  • · Replies 19 ·
  • · Replies 17 ·
10K
