| Thread Closed |
Understanding Heat Exchangers |
Share Thread | Thread Tools |
| Aug18-10, 03:23 PM | #1 |
Hi Physics Forum-ers, long time reader, first time poster.
I've been given the task to do a simulation for the cooling of a motor from 50C to 20C. The motor is cooled using a water cooling system, and a 3.5kW heat exchanger. I've done some quick preliminary calculation, but I'm getting stuck on the limits of the heat exchanger. My current formula looks like: Twater(1) = Twater(0) + Heat From motor(~2kW) - Heat Removed From exchanger (~3.5kW) (I know I should use heat capacities and such, this is a simple model) Now, the heat exchanger we are using is specced to remove 3.5kW of heat. I was told that using this value independent of temperature is an acceptable assumption, but if I were to assume that this will continuously remove 3.5kW, the water temperature would eventually drop below freezing, and I don't think this is correct. What type of function should I be using to describe the heat removed by the exchanger? Other information: Refrigerant Conditions BXD: 16bar, 52C Refrigerant Conditions Suction: 3bar, 7K Coolant temperature 35C |
| Thread Closed |
| Tags |
| heat exchanger |
| Thread Tools | |
Similar Threads for: Understanding Heat Exchangers
| Transient heat transfer in heat exchangers | Mechanical Engineering | 2 | ||
| Dimple plate heat exchangers | Mechanical Engineering | 0 | ||
| Shell and Tube Heat Exchangers | General Engineering | 5 | ||
| Enthalpy with regards to heat exchangers and air | Classical Physics | 2 | ||
| heat exchangers | Materials & Chemical Engineering | 1 | ||
