| Thread Closed |
Non-constant index of refraction due to layered material. |
Share Thread | Thread Tools |
| Aug22-10, 06:17 PM | #1 |
A ray of light travels through a medium with an index of refraction [tex]n_{1}[/tex] and strikes an layered medium such that the index of refraction is [tex]n_{2}=ky+1[/tex] where [tex]y[/tex] is the depth of the medium and [tex]k[/tex] is a constant. If it hits at an angle of [tex]\theta_{1}[/tex] with respect to the normal, find the angle [tex]\theta_{2}[/tex] at which the light ray refracts as a function of time.
Source: A post that I made on the Art Of Problem Solving forum. |
| Aug22-10, 06:50 PM | #2 |
Mentor
As with all homework like questions you must show some work before getting help.
| Aug22-10, 09:38 PM | #3 |
My work:
So far I know that [tex]v=\frac{c}{n_{2}}[/tex] is the speed of the light beam, which is also equal to [tex]v=\frac{dy}{dt}[/tex]. So a differential equation to solve would be [tex]\frac{dy}{dt}=\frac{c}{n_{2}}[/tex] |
| Aug23-10, 12:51 AM | #4 |
Recognitions:
The light ray does not travel along y but at an angle θ2 with respect to it. θ2 itself is a function of y.
ehild |
| Aug23-10, 07:31 AM | #5 |
APhO 2004 problem 2. It is similar to this one. Look at the solution there.
| Aug23-10, 11:08 AM | #6 |
| Aug23-10, 01:15 PM | #7 |
Recognitions:
And how are y and θ2 related?
ehild |
| Aug23-10, 03:33 PM | #8 |
If the material is layered infintesimally so that the index of refraction is proportional to the y, which I stated in the problem, then y is related to [tex]\theta[/tex]2 because the index of refraction is related to [tex]\theta[/tex]2
| Aug23-10, 03:47 PM | #9 |
Recognitions:
What is the relation between the refractive index and θ2?
ehild |
| Aug23-10, 04:17 PM | #10 |
The refractive index and [tex]\theta[/tex]2 are related through Snell's Law.
| Aug24-10, 02:04 AM | #11 |
Recognitions:
Well. At depth y, the light ray encloses the angle θ2(y) with the y axis. The light travels along a curved path s and ds/dt = c/n2(y). At depth y, θ2 is obtained from Snell's law. Now you can set up the differential equation for θ2 as function of t.
ehild |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Non-constant index of refraction due to layered material.
| Reflection and Refraction, much index of refraction | Introductory Physics Homework | 6 | ||
| Making negative refraction with positive index material | Classical Physics | 16 | ||
| Index of refraction = sqrt dielectric constant | Classical Physics | 1 | ||
| Refraction Index vs. Material Thickness | Atomic, Solid State, Comp. Physics | 8 | ||
| dielectric constant and index of refraction | General Physics | 3 | ||
