| Thread Closed |
shunt resistor right application? |
Share Thread | Thread Tools |
| Aug24-10, 03:32 PM | #1 |
I have a 400A (125VDC) charger that feeds a battery bank and a few DC panels (critical). This poor design has the panels being fed from the high side of a 600A breaker that is between the charger and battery bank. I need to take the battery off line for a load test but the problem I'm going to have is when I reconnect the battery to the charger I will have a current surge coming from the 400A charger to the unenergized battery bank (approx. 350A). This will most probably cause a voltage drop in the DC panels which I CANNOT have (critical loads on panels). Will a proplerly sized shunt resistor between the disconnect switch and panels work for this situation?
| Thread Closed |
| Thread Tools | |
Similar Threads for: shunt resistor right application?
| Voltage amplifier (15mV signal on 120VAC offset) for shunt resistor/current sensing | Electrical Engineering | 6 | ||
| dc shunt motors | Electrical Engineering | 4 | ||
| Need help locating high power shunt resistor | Electrical Engineering | 6 | ||
| induced current through a resistor - with variable resistor and two coils | Introductory Physics Homework | 15 | ||
| shunt motor | Introductory Physics Homework | 0 | ||
