How do you find the limits of integration of polar curves?
The discussion revolves around finding the limits of integration for polar curves, specifically focusing on the area enclosed by curves such as a cardioid and a limacon.
  • Participants discuss the standard limits of integration for closed curves in polar coordinates, questioning when these limits might differ. There is an exploration of how to determine if a polar function represents a closed curve and the implications for setting limits of integration.
Some participants have offered insights into the characteristics of polar curves and how to identify limits based on the geometry of the curves. There is an ongoing exploration of different cases, with no explicit consensus reached on a single method for all scenarios.
Participants note that the limits of integration can vary depending on the specific polar curve being analyzed, and there is mention of the need to find points where the curve crosses itself to determine limits accurately.
Soubriquet
Find the area of the region in the plane enclosed by the cardioid [tex]r = 4+4\sin{\theta}[/tex]
The book explains that "Because r sweeps out the region as [tex]{\theta}[/tex] goes from [tex]0[/tex] to [tex]2{\pi}[/tex], these are our limits of integration."
When working in Plane Polar coordinates, if you are talking about closed curves, then [itex]\theta[/itex] always goes from 0 to [itex]2\pi[/itex].
In another question, the limits change. How do I tell if the function is a closed curve?
The question is "Find the area inside the smaller loop of the limacon [tex]r = 1+2cos(\theta)[/tex]."
The books gives the limits [tex]2(\pi)/3[/tex] to [tex]4(\pi)/3[/tex]."
It's not always from 0 to 2pi. The best way to learn this is to really just familiarize yourself with polar curves. Do you know what a limacon looks like? If yes, you should be able to picture the small loop (there's only 1). Geometrically, this means that your polar curve crosses itself for somewhere. Algebraically, this means r = 0 for two values of theta between 0 and 2pi. So simply find these two values of theta. They will be your limits.
Is there a program that gives theta in terms of pi instead of decimals?
  • · Replies 19 ·
  • · Replies 16 ·
