Designing the Perfect Egg Drop Package: Tips and Tricks for the Competition
The discussion revolves around designing a package to protect an egg during a 6-foot drop for a competition. The package must meet specific criteria regarding size, weight, and materials, and the scoring is based on the egg's survival and proximity to a target.
  • Exploratory, Conceptual clarification, Problem interpretation, Assumption checking
  • Participants suggest focusing on lightweight designs and avoiding bounce to prevent egg breakage. Some mention the potential effectiveness of crumple-style packages and parachutes. Others share personal experiences and propose testing various designs to find effective solutions.
The discussion is active, with participants sharing insights and experiences related to egg drop designs. Some guidance has been offered regarding design considerations, such as slowing the rate of fall and reducing impact force. There is an emphasis on allowing the original poster's son to contribute ideas to the project.
Participants note constraints such as the competition rules regarding package construction and materials, as well as the importance of accuracy in landing the package on the target.
nautica
I am helping my son with the following:
Egg Drop Competition
Design a package to hold an egg during a 6' drop without breakage.
Score is based on how close to the target the package lands and tie
will be decided by lightest package.
The Competition:
1. All pre-constructed packages will be brought to the drop sight.
2. The Egg:
- Each team will receive one Large Grade A egg on sight
- Students are responsible for the egg during loading, dropping, and
unloading
- Inspection of the egg should occur by both judge and team members
upon receiving the egg. Once the team receives the egg all questions
regarding its conditions becomes null and void
- The team must hand the egg to the judge once the drop is complete
3. The Package
- The package mmust be constructed at home
- maximum size is 8" X 8"
- max weight is 2 lbs
- no glass or metal
- package may not contain anything that would aid it in sticking to the
target (tape, rubber, ticky-tak, ect...
4. The Drop
- package dropped free fall by one student from at least 6'.
- There will be one drop with a time limit of 2 minutes from the time
judges say begin
5. The drolp area will be 2' x 2' and made of a solid material
(plywood or cardboard) with a target in the center.
SCORING
Only eggs surving will be scored. The farther distance of any part of
package to center of target will determine score. Shortest distance
wins.
Tie breaker goes to lightest package.
Any ideas would be greatly appreciated.
Thanks
Nautica
Go for light-weight, almost everyone will successfully not break the egg if the drop is only 6'. I've had my classes drop their eggs from 25 feet, and very few of them broke.
And you do NOT want the backage to bounce (bounces break eggs).
It sounds like the judge is expecting people to use parachutes. If you build a "crumple" style package, you can probably hit the target very closely. It will probably take a fair amount of calculation and testing to build a good "crumple" package - where the package crumples to protect the egg and keeps the acceleration low. "Toothpicks and glue" are a classic crumple design, but you'll have to do some research and probably some testing (at home) for yourself to come up with a winner.
Yeah I wouldn't worry about the egg breaking
I had to do something simliar except in a coffee can
My package did great
I could through it over a 2 story house down an extra 50 ft and it couldn't break the egg.
Just work on accuracy.
maybe tiped arrow design that is planed to crumble when it hits
if it is only 6 ft
Wow! When I was younger, I took part in a competition in which we had to design an egg-drop device out of only newspaper and cellotape! Then, we had to drop it from a height of TEN FEET! My egg did not survive the fall. Can anyone please tell me how to my design could have worked? No one's egg survived in the competition! :eek:
There's an old addage:
It's not the fall that hurts, but the sudden stop at the end.
There are really two basic things that an egg drop can do:
Slow the rate of fall. (Parachutes) These egg drops work by making the impact so slow that it won't break the egg.
and
Reduce the impact impulse. (Cushions) If you have a large cushion, then the egg will impact the cushion and stop over a longer distance rather than stopping over a short one. This reduces the force on the egg.
It should be possible to construct an effective egg drop with either of those two tactics using only newspaper.
Regarding the original post:
In general, my advice would be to talk this over with your son, and have him propose ideas (keep the two things above in mind). Look for ideas that are easy to build, cheap, and easy to test. Invest in a dozen eggs, and try the ideas.
Nate TG made a couple very good points.
The impulse he is referring to is related to momentum. Impulse is equal to the change in momentum that occurs (in this case the change in momentum starts with the eggs initial momentum (eggs mass X velocity) and 0 (because the egg will stop). Change in momentum is also equal to the total force X change in time. Because the force of the fall will remain the same, you must find a way to increase time. This is where a cusion could come in handy.
Using a combination of a parachute and a cushion would be the most effective way to ensure the egg doesn't break.
Most importantly you must remember it is your sons project, and he won't learn anything if you do it all. Let him come up with ideas, and support the ideas that are logical.
Oh yeah... have fun with it too! :smile:
61K
  • · Replies 16 ·
32K
15K
13K
  • · Replies 37 ·
15K
  • · Replies 0 ·
