Electric Fields x-component problem
The discussion centers on the x-component of the net electric field in different quadrants of a Cartesian plane. In the first quadrant (x > 0, y > 0), the x-component is always positive due to both the uniform electric field and the charge contributing positively. Conversely, in the third quadrant (x < 0, y < 0), the x-component is always negative as both contributions are negative. The rationale provided by participants confirms that the net electric field's behavior is consistent with the signs of the components in each quadrant.
  • Understanding of electric fields and their components
  • Familiarity with Cartesian coordinates
  • Knowledge of the behavior of electric fields from point charges
  • Basic principles of vector addition in physics
  • Study the concept of electric field lines and their directionality
  • Learn about the superposition principle in electric fields
  • Explore the effects of distance on the strength of electric fields from point charges
  • Investigate the mathematical representation of electric fields in different quadrants
Students of physics, educators teaching electromagnetism, and anyone interested in understanding electric field behavior in different spatial configurations.
masamune
1) In the first quadrant (x > 0, y > 0), the x-component of the net electric field is:
always positive.
always negative.
sometimes positive and sometimes negative.
2) In the third quadrant (x < 0, y < 0), the x-component of the net electric field is:
always positive.
always negative.
For the first part, I explained that in the first quadrant, the x and y components of the field are both positive and so the net electric electric field will always be positive. Conversely, in the third quadrant, the x and y components of the field are always negative and so the net electric field will always be negative. Is my rationale correct? Refer to the attached pic btw if you have no clue what I'm talking about.
Get in the habit of stating the problem clearly. I'm guessing that the picture is meant to show a positive charge Q placed in what was a uniform electric field in the +x direction? And the problem refers to the net field?
All they ask about is the x-component, so that's all you need consider. But, yes, both contributions to the net field are positive, so your answer is correct.
No. The uniform field has a positive x-component, but the field from the charge is negative. But the magnitude of the field from the charge varies with distance. Think it over again.
sorry about that doc. you assumed correctly though. thanks for your help
  • · Replies 22 ·
