Revolutionize Energy Storage: Utilizing Flywheels for Efficient Power Generation
This discussion focuses on utilizing flywheels for energy storage, specifically a 10 kg steel flywheel with a moment of inertia of approximately 1 kg.m², charged to 7,000 RPM to store 268 KJ of energy. The charging mechanism involves a Honda GX50 engine, which provides a maximum torque of 3 Nm at 4,000 RPM and a maximum power output of 1.6 kW at 7,000 RPM. Key questions raised include calculating the charging time without intermediate devices and determining the discharge characteristics for a light vehicle weighing 170 kg.
  • Understanding of flywheel energy storage principles
  • Familiarity with rotational dynamics and energy calculations
  • Knowledge of small engine specifications, particularly the Honda GX50
  • Basic principles of mechanical coupling and energy transfer
  • Research energy balance calculations for flywheel systems
  • Learn about direct coupling mechanisms in energy transfer
  • Investigate the characteristics of energy discharge in flywheel applications
  • Explore practical implementations of flywheel energy storage in vehicles
Engineers, researchers, and hobbyists interested in renewable energy technologies, particularly those focusing on innovative energy storage solutions and applications in light vehicles.
grey
I have an idea pertaining to energy storage in flywheels, something like they do in the KERS, and need assistance here...
Ok, my idea involves using a flywheel of around 10 kg (steel) with I~1 kg.m^2, to be charged to an RPM of around 7,000 RPM.
This allows E = 0.5 x 1 x (7000x2x pi /60)^2 = 268 KJ of energy to be stored.
I want to charge it with a small engine (something like a Honda GX50) which, according to the charts will give max torque of 3 Nm at 4000 rpm and max power of 1.6 kW at 7000 rpm (approx).
I want to discharge it to run a light vehicle (170 kg including driver) such that the discharge takes place at one wheel only (a three wheeler). I want discharge in pulses.
Now, the questions:
1. How do I calculate the time it takes to charge the flywheel to 7000 RPM? Can I do it without using some intermediate device like a CVT or motor/generator?
2. How do I calculate the discharge time (and characteristics)?
Thanks in advance.
I think flywheel energy storage is a really interesting topic, I would love to see more practical uses of them! If you end up making something, please post it.
Now, the questions:
Thanks in advance.
Hi-
1. The time it takes for increase the kinetic energy of the flywheel mainly (but not finally) depends on the characteristics of the energy supplier (your GSX50) and utilizer (in a direct coupling). Write down the energy balance and you will get the dynamics (and then the time). But direct coupling seems to me a not real event..
2. For the discharge time you can use the same approach, this time the flywheel is the motor.
M
  • · Replies 27 ·
13K
16K
20K
