Position of a Particle as Function of Time (Velocity, Acceleration, etc.)
The discussion revolves around determining the velocity and acceleration of a particle given its position as a function of time, represented by a quadratic equation. The specific values for the constants in the equation are provided, and the problem is set within the context of physics and calculus.
  • Participants explore the substitution of time into the position equation to derive velocity and acceleration. Some express uncertainty about the calculus concepts involved, particularly derivatives. Others attempt to clarify the relationship between the position function and its derivatives.
The discussion includes attempts to derive formulas for velocity and acceleration from the position function. Some participants have provided guidance on the necessary calculus concepts, while others are still grappling with the application of these concepts. There is a mix of understanding and confusion regarding the use of derivatives.
One participant notes a lack of calculus knowledge, which may impact their ability to fully engage with the problem. The discussion also reflects varying levels of familiarity with the relevant equations and concepts, indicating a learning environment where participants are seeking to clarify their understanding.
09jml90
The position of a particle as a function of time (in s) is given by C1 + C2t + C3t2.
Let C1 = 19.0 m, C2 = 39.1 m/s, and C3 = -0.62 m/s2.
(a) What is the velocity of the particle at time t = 13.0 s?
(b) What is the particle's acceleration at time t = 13.0 s?
C1 + C2t + C3t2.
I wasn't sure how to do this problem from the beginning, so I tried playing around with some numbers to see if anything could come up. I tried substituting 13.0 into the formula to create a quadratic equation and got: -104.78x2 + 508.3x + 19. I then used the quadratic formula to get some points: (-0.037, 0.0495) (4.888, 0.06186). If I'm doing anything right so far, I would say from the graph that the velocity is decreasing and the acceleration is negative?
Any help would be greatly appreciated. Thank you.
So you have (after substituting the Cs) s=19+39.1t-0.62t2.
You need to get 'v' and 'a' when 't=13'. All you need to do is remember your Relevant Equations
v=ds/dt and a=dv/dt
I actually haven't taken calculus and don't know derivatives yet but I'm taking physics and calculus simultaneously right now. I'm going to try to look derivatives up and see what I can come up with and post my solutions.
Thanks for the tip. I'll let you know what I get
Well for your problem, you just need to know that
y=tn then dy/dt=ntn-1 for all n.
What does "n" stand for in the equation
'n' is a constant so it can be any number.
Wait never mind. Just saw it.
Using the equation I'm getting -1.24? Is that anything?
That is for the velocity or acceleration?
I'm actually not sure. Can you use that equation to find both the velocity and acceleration?
And is this the "Simple Power Rule?"
I am not sure if that is the name of the rule.
But yes, you will use the initial equation to find the velocity and acceleration.
Remember v=ds/dt (so you will now have a formula for 'v') and then a =dv/dt (you will get a formula for 'a').
Oh I didn't even think about substitution. Man I suck at this more than I thought. One sec.
Velocity = 22.98 m/s?
Acceleration = -1.24 m/s2?
Yes, those should are correct.
Thank you for your help. Very much appreciate it.
