| Thread Closed |
Fine structure constant probably doesn't vary with direction in space! |
Share Thread | Thread Tools |
| Sep15-10, 04:13 PM | #103 |
| Sep15-10, 07:26 PM | #104 |
| Sep15-10, 07:30 PM | #105 |
| Sep15-10, 07:33 PM | #106 |
Also a varying alpha isn't that weird. |
| Sep15-10, 07:36 PM | #107 |
| Sep15-10, 07:39 PM | #108 |
One thing that you could argue in 1995, is that the energy level would settle at some value that would level space time "flat" but the discovery of the accelerating universe calls that into question. |
| Sep15-10, 07:44 PM | #109 |
e.g. http://adsabs.harvard.edu/abs/2008A%26A...487..583B Also, this does also does nothing to explain the Lyman-alpha forest -- the dense series of Lyman alpha transitions along the line of sight to the quasar which all occur below the Lyman alpha emission peak. High column density Lyman alpha absorbers have been identified with host galaxies at cosmological redshifts. Hydrodynamic Lambda-CDM simulations reproduce the observed statistical properties of the forest as far as I know. No-one takes the gravitational redshift explaination for quasar sources seriously anymore. |
| Sep15-10, 07:47 PM | #110 |
Suggesting that associated astronomical bodies *might* have discordant redshifts won't get you looked at funny. It's when you telling that the person you are talking to that they are an idiot and part of an evil conspiracy that will get you problems. |
| Sep15-10, 07:50 PM | #111 |
And one point that I'm trying to make here is that while "quasars are caused by gravitational redshift" is considered a nutty idea by people in the field, the idea that "the fine structure constant may be varying in space and time" isn't, and there are theoretical reasons why you are getting telescope time to look at this whereas as the gravitational redshift people aren't. |
| Sep15-10, 07:52 PM | #112 |
My co-conspirators and I are taking baby-steps, studying redshift differentials in M-51 type galaxy associations. Getting published is easy. Getting people to think about the implications is a bit more problematic. |
| Sep15-10, 08:04 PM | #113 |
Not to say this is a bad thing. Discovering that clouds are highly magnetized is as interesting as finding a varying alpha. |
| Sep15-10, 08:55 PM | #114 |
| Sep15-10, 09:29 PM | #115 |
alpha in flat space-time. How do you construct such a theory compatible with SR? Even if you could declare a preferred inertial frame in flat space-time, it would be arbitrary. A preferred frame could be part of the gravitational physics of some metric theory of gravity without violating the EEP (but the SEP would be violated). In that case, the preferred frame cannot be detected by doing local non-gravitational experiments. If it can, the the preferred frame must be part of some flat space-time theory to fulfil the EEP. Of course, according to GR, the frame of the CMB is preferred in neither way, it is just a frame where a lot of stuff is at rest, on average. source. A time-shifting alpha raises more fundamental problems. does indeed break GR. |
| Sep15-10, 10:14 PM | #116 |
space-time? It seems that all you have done, is to transfer the problems of varying alpha to the X-field. does/does not vary might well be one of them. And I cannot really see that you have answered my specific concerns regarding varying alpha. Note that I do not say that the idea of varying alpha is "nutty" or something like that, I just claim that it is radical, and with no particular theoretical motivation how to change the mainstream framework to implement it. To me, this seems to signify another dead end. with a careful assessment of observational results. That is, any extra assumptions specifically made to make observational results fit theory, is regarded with strong suspicion. Besides, I am well aware that what is presented as observational "facts" may well depend crucially on theoretical assumptions made when analyzing the data. Therefore it is important to analyze data within different frameworks. Since our views do not seem to converge, I think it's just as well to stop here, and just agree to disagree. |
| Sep15-10, 10:39 PM | #117 |
So what I'm proposing is that you have these clouds of Mg and Fe because they were undergoing massive star formation, and if that's the situation then you should have large numbers of black holes and neutron stars in the clouds. I think it's going to be rather difficult for you to come up with a scenario in which you have strong Mg and Fe lines in which you don't have some neutron stars or black holes floating around somewhere from the supernova that produced those elements. Also should I infer from the line of questioning that you haven't done an experiment to see if stray magnetic or electric fields will cause some effects mimicking a change in the fine structure constant? If you haven't or if you have and it turns out it does, then I think you should mention in the paper that you are assuming that the clouds don't have strong magnetic or electric fields in them. |
| Sep15-10, 10:45 PM | #118 |
When you are in the world of GR, you can get away with parsimonity, but that comes at the cost of ignoring much of the rest of the universe. Once you get out of the nice clean world of GR into the messy real work, then parsimonity just doesn't work. |
| Sep15-10, 11:50 PM | #119 |
As I noted earlier, our paper only has 4 pages. Even the long forthcoming paper doesn't describe everything in detail. All our current papers refer to the 2003 paper on systematics, which itself refers to the 2001 paper on systematics. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Fine structure constant probably doesn't vary with direction in space!
| Fine structure constant | Quantum Physics | 3 | ||
| Fine Structure Constant Varies With Direction in Space! | Cosmology | 6 | ||
| The Fine Structure Constant | Quantum Physics | 3 | ||
| Is Boltzman's Constant related to the Fine Structure Constant? | Quantum Physics | 6 | ||
