Modelling Salt and Water Flow in a Tank
  • Thread starter Thread starter DennisG
The discussion focuses on modeling the flow of salt and water in a tank using a differential equation. The equation represents 2 tons of salt entering a 20-ton tank of water each minute, while 2 tons of the mixture are drained each minute. The amount of salt, S, is defined as S = S_0 + \dot S × t, where \dot S is the constant rate of salt addition. The equation provided is \(\frac {d}{dt} \frac {S^2 + W^2}{S+W} = \dot S\).
  • Understanding of differential equations
  • Knowledge of fluid dynamics principles
  • Familiarity with mathematical modeling techniques
  • Basic concepts of saltwater mixture dynamics
  • Study differential equations in the context of fluid dynamics
  • Explore mathematical modeling of chemical mixtures
  • Learn about the application of the Laplace transform in solving differential equations
  • Investigate real-world applications of saltwater flow modeling
Researchers, engineers, and students in chemical engineering or environmental science who are interested in fluid dynamics and mathematical modeling of mixtures.
DennisG
set up a differential equation to represent 2 tons of salt entering a 20 ton tank of water each minute while 2 tons of the mixture are drained each minute
[tex]\frac {d}{dt} \frac {S^2 + W^2}{S+W} = \dot S[/tex]
where W(t) is the amount of water in the tank and S is the amount of salt given by [itex]S = S_0 + \dot S \times t[/itex] with [itex]\dot S[/itex] being the constant rate at which salt is added.
Are you sure about that tide? I could swear I tried that same thing, but I don't know, maybe I was just being an idiot. Thanks for the help
  • · Replies 20 ·
