Register to reply
What is the reflection coefficient on a transmission line at a resistor halfway?
Share this thread:
Rib5
#1
Aug31-10, 07:24 PM
P: 55
If I have a coaxial transmission line, with a resistor halfway through, and another resistor at the end, how do I calculate the reflection coefficient for the spot where the resistor is halfway?
Here is a diagram of what I mean. Dashes and dots are are the lines, and } are resistors.
....}a....}b
2. Relevant equations
[tex]\Gamma_{L} = \frac{Z_L-Z_o}{Z_L+Z_o}[/tex]
3. The attempt at a solution
I am pretty sure the formula I am supposed to use is [tex]\Gamma_L = \frac{Z_L-Z_o}{Z_L+Z_o}[/tex]. What I am not sure is what value to choose for [tex]Z_L[/tex]. Do I take [tex]Z_o[/tex] in parallel with [tex]R_A[/tex]?
Phys.Org News Partner Science news on Phys.org
Flapping baby birds give clues to origin of flight
Prions can trigger 'stuck' wine fermentations, researchers find
Socially-assistive robots help kids with autism learn by providing personalized prompts
xcvxcvvc
#2
Aug31-10, 08:23 PM
P: 393
you know how you can take any length of transmission line plus an impedance at the end, and transform it into a single impedance that the source sees?
Well, put your finger over resistor a and the rest of the circuit, and apply that formula to transform your circuit from
L/2 of wire-> impedance a -> L/2 of wire -> impedance b
into
L/2 of wire -> impedance a -> equivalent impedance B
you need to use the length L/2, not L, when you calculate the equivalent impedance for resistor b, because you're calculating the equivalent impedance that resistor a sees. Next, now that resistor behaves just like they do in your circuits class. Take equiv b in parallel with a (assuming a branches across and connects the wires) to find a single impedance at the "end of the wire" (which represents what impedance is seen at the halfway point). Then apply your reflection equation.
Register to reply
Related Discussions
Transmission and Reflection Coefficients Advanced Physics Homework 4
Transmission and Reflection Coefficients Advanced Physics Homework 0
Reflection and transmission of waves Introductory Physics Homework 8
Why the reflection and transmission? Quantum Physics 2
Reflection and Transmission Advanced Physics Homework 3
